Sand it off!
Use 600 minimum, but I recommend 400 grit. Sand it off. The gel coat does nobody any favors down the road if it fractures under your paint---and it will eventually---leaving surface fractures on your paint job. You are well-advised to get rid of it, fill in pinholes with straight epoxy, then sand down again before surface priming. Use 600 grit just before the first topcoat of paint.
