Old 09-14-2010, 07:30 AM
jartlip jartlip is offline
Default POH and Experimentals
Is there a requirement to have an aircraft flight manual/pilot operating handbook for an experimental airplane? The airplane I am looking at has the airworthiness certificate with operating limitations, weight and balance info, and placarded limitations on the side of the cockpit, but no POH. Is this all I need (in addition to my registration) to be legal? Or does some sort of POH need to be present?
Thanks...
Jim
RV-4
Old 09-14-2010, 07:42 AM
Sid Lambert Sid Lambert is offline
You do not have to have a POH with an experimental.
http://webcache.googleusercontent.co...&ct=clnk&gl=us
Sid Lambert
RV-7 Sold
RV-4 - Flying - O-320 Fixed Pitch - Red over Yellow
Auburntsts's Avatar
No POH required. You listed everything that you need:
Airworthiness Certificate
Certificate of Aircraft Registration
Operating Limitations
Weight and Balance Data
However, I think a POH is nice to have (I plan to write one for my plane).
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 09-14-2010, 07:45 AM
terrykohler terrykohler is offline
Default No POH required
OPs Limitations, W&B, placards, AW cert and Registration(s).
Should be good to go (I'm sure a DAR will jump in to verify). If there isn't already one for the aircraft, I'd suggest you take your time and develop a good checklist (not required) and actually use it. I know, I know, lots of RVers do it all from memory.
Terry, CFI
RV-9A N323TP
Old 09-14-2010, 07:51 AM
KatieB's Avatar
KatieB KatieB is offline
Default Phase 1
A POH is a great way to express all that exceptional performace data you collect in Phase 1.
Katie Bosman
RV-3B sold, but flying!
Next project: ???
Builders gonna build...
Old 09-14-2010, 11:22 AM
That was fast! Thanks for all of the replies!
Jim
RV-4
