Old 09-12-2010, 09:17 PM
skyking902001's Avatar
skyking902001 skyking902001 is offline
Default Elevator Rod End Bearing Question
Trying to adjust the rod end bearings on the elevators prior to drilling the horns thru the center bearing hole. How does one measure 13/16" from spar to center of the rod end bearing? I can eyeball what looks like the center and get close, but due to the swivel in the rod end, how can I be certain that I am measuring to the center of the bearing. Advice appreciated.
Skyking902001
RV8-emp almost done
Wings & fuse on order
Old 09-13-2010, 05:28 AM
cfiidon's Avatar
cfiidon cfiidon is offline
Default Try this
If I recall correctly, I stuck a bolt through the rod end. You can pretty much see that it is orthogonal to the shaft. You can then use a ruler or caliper to measure to the center, or perhaps to the inside and outside of the bolt shaft, add or subtract half the diameter, etc. I think you'll find that to be accurate enough.
Don
RV-8 QB Titan ECi 191HP XIO-360
WW200RV Dynon D180 HS34 AP74
GNS430 SL30 GTX327 PS8000B Uavionix Echouat
"Pilots are alchemists... we turn gold into lead."
Old 09-13-2010, 06:02 AM
Lockard's Avatar
Lockard Lockard is offline
Do you mean hexagonal or perpendicular?
If you were to scribe 2 lines on the top of the bolt head that go from peak to peak on the hexagon, they would indicate the center. You may be able to get a satisfactory amount of precision from that. Inserting a bolt is a great idea, though.
Maybe I'm over thinking this.
rzbill's Avatar
rzbill rzbill is offline
Default Bolt and scale
Like Don said, use a bolt as a visual aid.
Also, if you have a 6" scale (Starrett for example) that has marks on both edges, you can use that feature to help get the measuring bolt parallel to the Elev spar by reading the same measurement on both edges of the scale.
Bill Pendergrass
ME/AE '82
Old 09-13-2010, 06:50 AM
Dan Langhout's Avatar
Dan Langhout Dan Langhout is offline
Default I used a piece of 3/16" steel rod . . . . .
. . . . . through both rod ends. This pretty much takes care of ensuring that the bearing bore is parallel to the spar (once the two measurements get close). Measure to the center of the rod or to the edge with a 3/32" offset.
Dan Langhout
2020 =VAF= Dues PAID . . . . .
RV-7 N528DP slow build
First Flight July 26th, 2014
665 hours and counting . . . .
Now based at Moontown (3M5)
Old 09-13-2010, 12:20 PM
Bullseye's Avatar
Bullseye Bullseye is offline
I just tried to center the bearing and eyeball it.
If I remember correctly, it was clear when it was correct, as another half a turn was definitely too much, and a half a turn less wasn't enough.
http://n999za.files.wordpress.com/20...-012-large.jpg
Andrew Z.
Engineering Flight Test Pilot/Engineer, CFI-A, CFII, ATP
RV-7 in work (See my build log.)
Empennage...Done (except rebuilding the rudder.)
Wings...Halfway complete.
2018 Dues Paid
Old 09-14-2010, 07:25 AM
Default Thanks!
Thanks for the responses. I probably way over thought the issue--just didn't want to mess up. I ended up drawing some parallel lines on a ruler. I inserted an Averey alignment pin thru the rod end bearing, using the ruler behind the bearing to assure the pin was parallel with the spar. Although the alignment pin does not come to a sharp point, using another starrett rule, I was able to measure from the spar to the tapered end of the pin. Seemed to work out ok. Thanks again for the help!
Skyking902001
Old 03-26-2011, 04:50 PM
Experimental Chaos's Avatar
Experimental Chaos Experimental Chaos is offline
Default Over thinking?
You think you?re over thinking it? Not even close. I made a fixture by cutting two pieces of ? by 1 inch aluminum bar stock, drilled a 3/16 hole in each, and cut one end (of each) to the required dimension, as measured with a digital calipers. Actually, cut long and then sanded to the precise length. The two pieces eliminate the possibility of having the bearing cocked, by having one on each side. Simply slip a bolt though, with 2 washers on each side of the bearing, and the 2 fixture pieces outboard of that. The problem comes from the fact that you have to make adjustments a whole haft turn at a time?Don?t talk to me about over thinking things?.
Mike Mason
Fairfield/Vacaville, CA
RV-7 QB Working on Wings, Fuselage & Sanity
VAF 1351
AOPA 04067557
EAA 837577
mgmason1911@gmail.com
Old 03-26-2011, 05:36 PM
bret's Avatar
bret bret is offline
You will never get it perfect because you can only make 1/2 turn adjustments, your only concern will be to get it close to the specs, and then look at where you will drill the horns at the center bearing (bolt interfering with weld) and counter weight swing clearance at the HS.
