Where to Buy Aeroquip 816 Fittings
I am fabricating some Aeroquip 601 hoses w/SS braid. This hose calls for Aeroquip 816 hose fittings (at least Spruce sez so!). I need 45 deg -8D fittings, but can't find a source. Spruce sells only straights and 90's. I want to use Aeroquip, not knock-offs such as Summit or Pegasus fittings. A related question, are the Aeroquip FBM series fittings equivalent to the 816 fittings? I believe the FBM fittings can be used on 601 hose. Thanks
Jim Shannon
RV-8 N52VV
Charlottesville, VA
AFS 4500 EFIS & 3400 EFIS/EM
G430W - SL30 - G327 - G696 - G240
TT DigiFlight II VSVG w/pitch autotrim
VP-X Pro
