Old 09-11-2010, 09:20 AM
brian's Avatar
brian brian is offline
Default cost of nose gear SB for older -6A?
Does anyone on here recall what it cost to get the nose gear SB done on an older -6A? I understand that, on the older ones, the leg can't be modified and the leg has to go back to Van's so a new one can be match-drilled.
Any of you folks familiar with total cost for all this and turnaround time?
thanks,
brian
Brian Meyette, Cornish, NH
1995 RV-6A - N16RK (Ralph Koger) SOLD
RV-7A - incomplete, supercharged Subaru STi - N432MM - SOLD
2001 Quad City Challenger II LW - N28RT SOLD
www.meyette.us/RV-7Ahome.htm
Old 09-11-2010, 09:47 AM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
Don't know what "older" means but I sent mine (1997 vintage) back to Langair I think. Cost was not bad so I would contact them for details.
Old 09-11-2010, 10:42 AM
gasman gasman is offline
If your nose leg has a taper near the socket end, it is the OLD leg. see Vans SB 98-10-1. The fork thing came about on Nov -9-2007 service bullitons. If it has the taper, then send it in for a match drill on the NEW leg. Also, order the NEW fork.
Old 09-11-2010, 11:23 AM
brian's Avatar
Thanks for the replies. I understand what needs to be done. What I'm asking about is the cost & turnaround time for the new match-drilled leg and new fork. I can call Van's Monday and ask them, but I was hoping to find out cost sooner than that.
thanks,
brian
Old 09-11-2010, 11:38 AM
brian's Avatar
Default found it
I knew the info I was looking for wasn't in the SB, but I was able to find it in an FAQ for the SB:
WD-630-1 fork $154.00
U-603-3X leg $194.00
Wd-631-PC collar $25.00
Match drill $75.00 (ship directly to Van?s Aircraft)
U-713C L&R $14.65 each
so it'll be about $500, plus shipping
Old 09-11-2010, 03:20 PM
RONSIM's Avatar
RONSIM RONSIM is offline
Default on the -8A
that I fly, I bought everything new, including bolts, washers, nuts, and did not reuse anything, and then added the Matco axle system ---- so, about $800.00 total.
Drilling the new gear leg for the bottom nut cotter pin was the toughest part, and oh, by the way, the new gear leg comes unpainted/unpowder coated.
Old 09-11-2010, 03:56 PM
GEM930 GEM930 is offline
Is there a reason why the leg has to be replaced? I bought the die and cut the leg off and cut the threads while it was still on the plane. Everything worked fine. Is the new leg stronger? Been flying on it for over a year.
Old 09-12-2010, 01:51 AM
az_gila's Avatar
az_gila az_gila is offline
Exclamation Depends on the age of the...
..nose gear leg.
Vans info is here....
http://www.vansaircraft.com/pdf/sb07-11-9.pdf
and here -
http://www.vansaircraft.com/pdf/Nosegear_sb_faq.pdf
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 09-12-2010, 07:43 AM
brian's Avatar
It's interesting that at least one other person did the SB in place. On my -7A project, with Eggenfellner engine frame, there was just no way I could ever get the nose gear leg out without removing the engine and frame completely, so I did it in place. The process ate up the first die (made in Japan), then the second die (made in USA) finished up the job easily.
Old 09-13-2010, 08:11 AM
Richard@Langair Richard@Langair is offline
Just for my curiosity, how long did it take you to rethread your gear leg with it still in your plane?
I have only heard details of one other person who I think took 4 hours to actually make the threads and they had it out of the plane.
