Old 09-09-2010, 07:45 PM
iowaflyer iowaflyer is offline
Default firewall insulation
For starters, I've already done a search on the forum archives and haven't really found the answers I'm looking for.
I need to put insulation on the cockpit side of the firewall of an already-built RV-4. I'm mainly concerned about thermal insulation--sound proofing would be nice but isn't a priority. Any suggestions? A search turned up more info about what not to use than what to use. Obviously, flammability resistance is important.
Also, what do you guys recommend to glue it to the firewall?
Old 09-10-2010, 07:36 AM
My 1955 Cessna has a fiberglass pad there. It's not glued, but all the various through-parts run right on through it and the threaded parts hold it in place. It must have been installed very early in the construction.
There's a clear plastic overlay, too.
Ain't fancy but it works.
Old 09-10-2010, 08:10 AM
dpansier's Avatar
dpansier dpansier is offline
Default Firewall insulation
This thread will provide a ton of information on firewall insulation.
http://www.vansairforce.com/communit...ad.php?t=37012
Don Pansier
Green Bay, WI (GRB)
RV-7 N450DP
W9LYX
Antennas for Experimental Aircraft
www.deltapopaviation.com
Old 09-10-2010, 08:51 AM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
Is this stuff any good?
http://www.aircraftspruce.com/catalo...rewall2000.php
Neal Howard
Airplaneless once again...
Old 09-10-2010, 09:30 AM
vfrazier's Avatar
vfrazier vfrazier is offline
We like this stuff heat shield mat
It's inexpensive, fairly lightweight, very easy to install, and should last the life of the plane with minimal care.
We make no claims that it will stop Dan's raging flamethrower, but that's the job of the stainless firewall. However, it does help reflect heat and offer a layer of ceramic insulation to help keep your feet cool.
Bottom line: easy, cheap, durable, waterproof.
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
1-888-F1AIRCRAFT (1-888-312-4727)
www.flyboyaccessories.com
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold in 1994, purchased in 2018
Old 09-10-2010, 12:25 PM
IowaRV9Dreamer's Avatar
IowaRV9Dreamer IowaRV9Dreamer is offline
I'm interested in this problem right now as my firewall is finally "done". Do you recommend putting this stuff on the outside of the FW? If so, is its adhesive good enough or does it need some additional method of attachment.
Also, do you recommend putting some other material on the inside for sound reduction? If so, what would you use and how best to attach?
Dave Gribble VAF #232
Building RV-9A N149DG (slider, IO-320, IFR)
Restored and Flying Beech Super III N3698Q
Marion IA
Struggling with fiberglass
There is no sport equal to that which aviators enjoy while being carried through the air on great white wings." Wilbur Wright, 1905
Old 09-10-2010, 12:51 PM
mfshook62 mfshook62 is offline
Default Plastic Foam Firewall (soundproofing) Insulation Warning
I recommend that you do not use vinyl plastic foam (soundproofing) material on the cabin side of the firewall. If you are unfortunate enough to have an engine fire, the black "closed cell fire retardant" foam will alert you immediately as it produces the most choking fumes as soon as it heats up, melts, and quickly starts to smoke. Now you have 2 major problems to deal with; 1. you have a fire, and 2. you can't breathe. I considered using this material for soundproofing in my 9a and decided to test it. I placed a square inch of this black soundproofing foam on an aluminum sheet and heated the backside gently with a propane torch. The foam quickly melted and then produced the most acrid and unbreathable chemical fumes that you could ever imagine. If you are considering placing foam soundproofing material in your aircraft, try the above test and then decide. In my opinion, this foam should not even be on the market as a soundproofing material for aircraft.
Mike Shook, RV-9A, Dynon HDX,
CPI-2 Ignition, Catto Prop, EAA 124
Old 09-10-2010, 02:31 PM
flyboy1963's Avatar
Default test
I echo Mike, i did the same test, however primitive, with everything I bought.
The black foam, when encased in 2 layers of heavy aluminum foil, will still cook and out-gass. Ditto the grey rubber mat.
I used the foil faced woven fibre mat, attached with LATEX contact cement on the cabin side of my firewall, and taped seams etc. as needed with foil tape.
I'm sure this could be greatly improved upon, but it's fairly safe & effective from my point of view. I have no delusions about 'fire-proofing', I just hope i gained 30 seconds more margin from the fire.
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 09-10-2010, 03:40 PM
RVbySDI's Avatar
RVbySDI RVbySDI is offline
There are several threads dealing with this issue. My posts are in many of them but I do not have time to link them to this message. Do a search on Firewall insulation and you will find them. To answer your question about whether the adhesive is good enough. I mounted the material I used on the engine side of the firewall with no adhesive except some aluminum foil tape along all edges and around all firewall penetrating wires, cables, etc. All of the various parts that are bolted to the firewall then were bolted in place. This "sandwiched" the insulation material between the firewall and battery box, brake reservoir, etc. etc. All of the various bolted components are proving to be more than adequate enough to hold the insulation material in place on the firewall.
Hope this helps.
RVBYSDI
Steve
RV9A
https://rvwings.com
Live Long And Prosper! 🖖🏻
Old 09-11-2010, 09:03 AM
vfrazier's Avatar
RVBYSDI is correct. The HeatShield mat goes on the engine side. Seal it down along the outer edges with RTV or ProSeal for a tidy installation. Mount your other components as usual and they will help hold the sheet in place should the adhesive lose its grip. Remove the HSM under the engine mount points or other critical components that must be 100% tight and secure (use common sense here).
We also have FAA burn rated closed cell foam for the cockpit side. Let's be clear here... FAA burn rated means it will only slightly kill you if exposed to flame. If you're not cool with that, use something else. Good luck finding the magical material that emits no fumes when heated AND is suitable for the intended purpose.
IMHO, the intended purpose is keeping my feet cool. My parachute is how I intend to handle any serious fire.
Please don't construe my comments as flippant. In my view, this is the best compromise for MY comfort level as I hate the thought of burning up more than I hate the thought of losing a $100K airplane.
Also, hats off to Dan Horton for making this an issue that people take seriously. You should take it seriously!!! An inflight fire is your worst nightmare.
Vince Frazier
www.f1aircraft.com
