Old 09-08-2010, 06:43 PM
jeffmoreau's Avatar
jeffmoreau jeffmoreau is offline
Default CHT's Lower with Wheel Pants
Does this make sense? I flew my RV-8A with the main gear leg fairings and wheel pants installed for the first time today.
My cylinder head temps had been running a bit high, however today they were almost perfectly in line with what they should be.
Has anyone else experienced this?
Please let me know. Any comments are welcome.
Jeff Moreau
RV 8A
N888JM/Flying
EAA Technical Counselor
Virginia Beach, VA
Old 09-08-2010, 07:34 PM
odens_14 odens_14 is offline
Same thing happend to me. In my mind the equation went something like:
Gear leg fairings and wheel pants = higher airspeed = more cooling air through the cowl = lower CHTs
Chris Odens
Alexandria, MN
RV-7 N914N
FLYING!!! as of 7/22/10
Build Log
Old 09-08-2010, 07:35 PM
AlexPeterson's Avatar
Makes complete sense. If you've gained 10 to 15 knots or more, that is about 10% more cooling air for the same power. These RV's, fortunately, do not have excess cooling (i.e., drag).
This is one reason I have never understood Van's recommendation to do initial flights without gear/wheel fairings. Why try to break in an engine with even higher cht's? It makes sense if the engine is already broken in, to find out if the airplane itself is rigged properly, to fly without the fairings. Perhaps the recommendation came at a time when most flew with run-in engines. My perception is that most are newly overhauled or new now.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
Old 09-08-2010, 07:38 PM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
Define "a bit high" as with numbers.
Old 09-08-2010, 07:41 PM
jeffmoreau's Avatar
Default Definition
I was seeing temps just over 400 in the climb on the number 1 and 2 cylinders.
Jeff Moreau
RV 8A
N888JM/Flying
Virginia Beach, VA
Old 09-08-2010, 07:50 PM
Ron Lee's Avatar
I see 420 F or higher in a climb.
Old 09-08-2010, 07:54 PM
Jeff,
Unless the OAT was exactly the same for both observations, you don't know for sure if there was an improvement. A 20? difference in OAT will result in about that much CHT difference.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 09-09-2010, 01:37 PM
MauiLvrs's Avatar
MauiLvrs MauiLvrs is offline
Now I feel better....
How do you get 300 and anything in climb on a 100 deg day in an RV?
Dave & Trina
RV-9A Flying - 330 Hrs. Painted Finishing the interior.
Old 09-11-2010, 10:31 AM
Rob Erdos's Avatar
Rob Erdos Rob Erdos is offline
Default ...and for comparison...
...the coolant temperatures actually drop in the Me-109 when you partially close the radiator doors. Decreased drag provides more speed and better cooling. Surprising, at first.
Rob
Old 09-13-2010, 09:41 AM
trib trib is offline
There is some logic is reduced CHT's with the fairings on. At any single condition, climb or cruise, since the fairings reduce drag, the engine requires less power to maintain the same speed, therefore lower CHT's.
This would actually be more pronounced at higher speeds, as drag varies proportionally to the speed squared. In climb I would think the difference would be rather small. I can quickly get to 400F and even 415F in climb at 120 mph. A climb at 140 mph will stay below 400. Your engine is still breaking in and you could be experiencing lowering temperatures as internal frictions decrease.
Tim Ribble
Virginia Beach
RV-6A (only took 13 years to build )
N621TR In unrestricted operation
