Old 09-07-2010, 06:56 PM
dbuds2's Avatar
dbuds2 dbuds2 is offline
Default ECI Vertical Fuel Injection
I did a search and did find lots of great info about brackets, cables, vertical, horizontal, and other FI systems, but didn't find a previously successful design for the throttle bracket.
My configuration:
RV-8
ECI IO-360,
ECI Vertically mounted throttle body,
FAB Airbox-snout intake,
Robbie Attaway mixture bracket,
I started modifying the VA-149 Bracket and then thought I'd make a new solid cable bracket plate (3/16" aluminum) to sandwich between the throttle body and spacer. Then I realized the lever arm is on the same side as the FAB Airbox and might interfere. The arm could be rotated up, but, then the action is reversed on the cable function. Is the VA-182 bracket oriented correctly?
[IMG] [/IMG]
Suggestions Please. Photos please.
Bud Smith, RV-8, ECI IOX360 , Dual PMags, Dynon SkyView, Whirlwind 200GA, IFR and N88ZP has "slipped the surly bonds of earth".
