Originally Posted by Rivethead
I was under the impression that the cowling was only to be installed with an engine and it's plenum installed. Am I wrong? It seems I read this in the assembly manual.
I'll repeat what Rivethead says... You have to have an engine mounted prior to installing the cowling. The prop flange location is required as a part of the cowling installation!
Step back and think carefully before you put the cart before the horse.
