Old 09-06-2010, 09:34 PM
newimaging's Avatar
newimaging newimaging is offline
Default Rivet hole to close to HS-405 & 702 ?
So I made my first mistake, and was wondering if I need to order new parts or if it might slide or be fixable.
When drilling the HS 405 & HS-702 thrue the skin, I din`t push them hard enough together, and then noticed that the resulting rivet holes doesn`t quite have the 2x distance to the edge. See pictures below. Its the hole on the right bottom.
Christian Stoehr
Winnetka, CA 91306
Looking for a Fuselage
http://www.stoehrfamily.com/airplane
Old 09-07-2010, 01:07 AM
ignacio ignacio is offline
doesnt look too bad but if you look in ac43 or the manual that came with kit, there is min and max edge distances for -3 and -4 rivets.
Old 09-07-2010, 02:41 PM
SeanB's Avatar
SeanB SeanB is offline
Default Probably okay
This is a common issue. I would send your pic to Vans and let them judge. I had similar spacing on that part and they were okay with it. The call could save you time and dollars.
SEAN BLAIR V7
Colorado Springs, CO
http://www.mykitlog.com/sblair
2020 VAF SUPPORTER
Old 09-07-2010, 04:45 PM
Patch Patch is offline
Default It is to print
Christian,
If you look at View B-B Zone 9B of DWG you will see that this is the edge distance shown on the drawing. On the aft side of the HS-702 you will see a phantom line that is the HS-405 edge in question.
I was concerned about this previously and discussed with Van's. They confirmed that it was to print.
You are good to go,
Scott
Old 09-08-2010, 12:23 AM
newimaging's Avatar
Thanks guys, I e-mailed Vans and got a response by 8am this morning. Have to say, didn`t expect it that fast. They said I am fine and its exspected on that part.
Thanks for the input.
Christian Stoehr
Winnetka, CA 91306
