Old 09-06-2010, 01:06 PM
B25Flyer B25Flyer is offline
Default Oil Consumption problem found....
The Rocket has been slowly increasing oil consumption for over a year. I could see that the problem was on the left side of the engine based on the soot on the left side of the belly. The compressions are all in the mid-70s so it either had to be an oil ring or valve guide.
I flew to TX last week and in 4 hours I added 3 qts so I decided that it would not wait until winter, so I pulled the cowl and pulled the plugs on the left side.
#4 was oily so I pulled the exhaust. 2 and 6 were nice and tan and 4 was coal black and sooty, so I pulled the cylinder.
As the Cylinder came off pieces of the oil ring feel out on the floor.... There is a gouge in the ring groove where the broken piece was located. The cylinder looks good!!! I think a hone job and new piston will solve the problem....
1100 hours and everything else looks good, and nice and clean inside.....
Tailwinds,
Doug Rozendaal
F-1 Rocket
Old 09-06-2010, 01:49 PM
pierre smith's Avatar
Default I'm curious....
...as to how and why an oil control ring can break while it's seated in the groove...hmmm.
Was the oil consumption good, early in the engine's life?
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 09-06-2010, 02:09 PM
I bought it with 300 hrs and it has about 1100 now. It has always used some oil, but it has been on the increase for the last year.
My Mech. said that this is pretty common...
Doug Rozendaal
Old 09-06-2010, 02:47 PM
Walt's Avatar
Walt Walt is offline
Just an FYI, cylinders are usually replaced in opposing pairs (to keep the engine inertia forces balanced). If you do just one piston, you need to get one as close to the same weight as the one you are replacing as possible.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 09-06-2010, 02:59 PM
The parts all came from Barrett and I am hoping they have a record of the piston weight and can match it....
Doug Rozendaal
Old 09-06-2010, 05:41 PM
rocketbob's Avatar
Best,
If there is a pronounced wear step on the cylinder at the bottom and top of piston travel, that can/does cause the rings to flutter and eventually break. Broken rings aren't uncommon.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
