Old 03-08-2006, 09:18 PM
aadamson's Avatar
aadamson aadamson is offline
Default Fire extinquishers (size,type)?
So, for those that have them, in the cockpit, I'm looking for something "smallish" but effective. We're talking portable here btw. Ya can't get Halon anymore, so what are ya using and how large are they?
Thanks in advance,
Alan Adamson
Atlanta, GA
Lancair Legacy FG-6 - N60AL (fixed gear, carbon fiber, IO-550)
Lancair Legacy Builders Forum
Beta Test Blog of Vertical Power install
Old 03-08-2006, 09:55 PM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
Default I am pretty sure Halon is available
Thanks in advance,
Alan you can get Halon, it is just HazMat if shipped. The Montreal Protocol
and the Clean Air Act, did outlaw new Halon production in 1994, it is still legal
to purchase and use recycled Halon and Halon fire extinguishers. In fact, the
FAA requires all commercial aircraft to exclusively use halon. Freon and Halon
both used for aerospace are exempt from the ban.
http://store.yahoo.com/stylespilotshop/12hafiex.html
(notice for aviation use only at bottom of page)
Halon is the only thing you can use in the cockpit. So if it was no longer
available, we would all be in trouble. You can get smaller Halon units than
above 2.6 lbs, but that is the smallest I would buy. For hand held portable
fire fighting Halon 1211-1301 is ideal for electrical fires (Class B/C), and will
not kill you with toxic chemicals. Dry Chem is out of the question.
Since you have a composite plane, PLEASE don't think I am picking on you or
being a "Wisenhiemer scientist", but composite and fire don't mix, really .
I would get a second large fire extinguisher to supplement the small halon
unit.
As far as size, besides one small 2-3lb handheld Halon for electrical fires
behind the instrument panel, you can handle with one hand, I would get a
much larger one, also Halon, CO2 or even dry chemical for exterior use only.
Dry chemical may be more effective for exterior, fuel, oil, brake-fire fires but
leave a mess, but that may be better than the fire getting away from you.
CO2 has the advantage of not leaving residue. Halon would work for the large
extinguisher as well but is expensive.
Good Luck, George
Besides Halon there are other trade marked legal substitutes to Halon,
Halotron I and PhostrEx to name two.
Old 03-08-2006, 10:05 PM
fireandfly fireandfly is offline
Question
There are a ton of extinguishers available but be ready in the cockpit for what comes out of the nozzle.
A combination extinguisher "ABC" (the most common) is like talcom powder. It gets into everything!! If you ever need to use it in the air - be ready to hold your breath and close your eyes. It's not harmful if it gets in your mouth, but it will dry everything out. It will completely fill your cockpit with powder, so be ready to get rid of it somehow so you can see out your windscrean.
The "A" means it will put out common combustibles, seats, carpet, lap boards, clothing, cup holders The "B" means it will put out flammible liquids, and the "C" means it will put out energized electrical equipment. What it really means is that the electricity will not flow up the powder stream and electricute you. Not much worry in a plane, but maybe at home or a hanger where the real electricity is.
CO2 is the next best from halon, but may be difficult to find in small tanks. It works by displacing the oxygen. It leaves no residue or mess. Very Clean!
Neither of them cool what was on fire much, so leave a little in the tank incase you need to use it again before landing. What's most important is to just get one! It's better to have a chance at landing, then no chance at all. A fire inside a GA plane will be unsurvivable within a minute or two if nothng is done. Not only is the fire BAD but the burning plastics will poisen your lungs. With that - Safe flying!
Old 03-08-2006, 10:39 PM
arffguy arffguy is offline
George and FireandFly are right. You can buy either one but new Halon is not being manufactured. Halon has been replaced with Halotron 1 which is less toxic to the environment than Halon. Here are just a couple of sample pages from Sporty's:
http://sportys-catalogs.com/acb/show...&CATID=96#desc
http://sportys-catalogs.com/acb/show...6804&CATID=178
Of course, notice the Halon has the same BC rating with less agent weight. Don't you just love "progress"?
Good shopping.
Mike F
RV-6A wings/fuselage
RV-3 empennage (extra thanks to Mr. Zilik)
RV-4 Plans only S/N 2938
Cessna 152
Elk Grove, CA
VAF #744 Exempt but paid anyway
Old 03-08-2006, 11:34 PM
rv8ch's Avatar
rv8ch rv8ch is offline
Default What is the risk?
Has anyone ever heard of someone getting a fire in the cockpit (not under the cowl) while flying, and then put it out, and land safely?
I would think that most events like this would not show up in the NTSB database, since there was no crash, so it's kind of hard to find info.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 03-09-2006, 12:06 AM
gvgoff99's Avatar
gvgoff99 gvgoff99 is offline
Default Halon
Originally Posted by fireandfly
A combination extinguisher "ABC" (the most common) is like talcum powder. It gets into everything!! If you ever need to use it in the air - be ready to hold your breath and close your eyes. It's not harmful if it gets in your mouth, but it will dry everything out. It will completely fill your cockpit with powder, so be ready to get rid of it somehow so you can see out your windscreen.
Yup, the dry chemical is not for use in the cockpit or ANYWHERE on an aluminum plane. The chemical will get everywhere and will be IMPOSSIBLE to remove later. It will then proceed to act as a corrosive agent. I know all the arguments of how the plane is not important. True, but fires do happen that are not life threatening and when the plane is on the ground. It is best to have an extinguisher that will put out the fire and not put the plane out to pasture via corrosion. Again, ?The agony of poor results lingers long after the sweetness of cheap price has worn off." Get Halon. Check out eBay. There are several reputable brokers there selling for less than $100.00.
George Goff RV-6A (Flying 3/7/2006 )(Houston, TX)
Old 03-09-2006, 12:39 AM
Default Hear is a Halon unit in my RV-6A
This is how I installed the Halon unit from Aircraft Spruce in my RV-6A. The current catalog still shows them available. Mine is not the smallest size.
Bob Axsom
Old 03-09-2006, 12:49 AM
Red face It could happen?
land safely?
Very spacific question. Of course there has been cockpit fires, almost
always and typically electical. A extingisher is handy for putting out
more than just the cockpit fires.
Cirrus saved by onboard and near by fire extinguisher
There has been more than one brake fire on RV's:
RV brake fire could have been total
Than there is a ton of smoke in the cockpit stories:
http://www.ntsb.gov/ntsb/brief.asp?e...06X00600&key=1
http://www.ntsb.gov/ntsb/brief.asp?e...08X09213&key=1
http://www.ntsb.gov/ntsb/brief.asp?e...12X22248&key=1
I see you are not arguing that it could happen, but has there been any
cases of a "SAVE". George
Old 03-09-2006, 01:12 AM
Default Well I saved my car
When I was flying to work every day at JPL I used to have an old light blue 1978 Ford Fairmont that I left in the parking lot at El Monte. One day I started the car and it caught on fire - underneath in the area of the catalitic converter. I ran back to my plane, got the fire extinguisher and put out the fire then drove to work. I drove that car for seven years that way before it finally demanded that I donate it to charity. That's kind of an aviation related save.
Bob Axsom
Old 03-09-2006, 06:48 AM
Tom Maxwell Tom Maxwell is offline
Default What about side effects?
OK, putting out the fire is important. And so is breathing. Halon and CO2 work by displacing the oxygen. Is it generally accepted that there is enough turnover of air in the cockpit that if I discharge a halon extinguisher I am not going to suffocate myself? And if there is enough turnover of air, is the halon going to be effective on the fire? My only experience with halon has been in the large data centers where when the red light starts flashing, it is best one remove themselves from the room.
Tom & Connie Maxwell
Houston, Texas
RV7A
N512TC
