Delay
There are 2 top skins on the fuselage.
I riveted the rear one in place about a year ago just to stiffen the structure a bit. This worked fine and was helpful for flipping the fuse upside down for the majority of electrical system installation. I left the fwd one cleco'ed and I am glad I did. There is enough "systems" work, such as static/electrical runs/AP servo that I would recommend leaving the fwd skin loose. Even with that, I still had to crawl into the tail recently to finish up the electrical runs. PITA. I wish I had positioned my ADEL clamp mounts while it was easy to access.
If you decide to rivet, make sure the seat belt anchors are complete, and the little angle brackets on some of the bulkheads are done. Pay attention to the order of rivetting the rear mount for the top center longeron. Rivet too soon and you loose access to bucking a skin rivet. If you are building tip-up, take a look at rear window install before riveting the fwd skin.
**EDIT** On re-reading the thread, I see Scott may be talking about the bottom of the canoe instead of closing the top. The only thing I remember from that event was regretting not dimpling the hole for the rudder cable exit ADEL clamp mounting screw. If memory serves, it was prepunched, so there was nothing preventing prep of that hole. It's kind of a pain to dimple later (with gun and dolly) but it's OK as long as you don't slip.
Bill Pendergrass
ME/AE '82
Reason: second thought
