Old 09-01-2010, 08:50 AM
777drvr 777drvr is offline
Default Radio noise while transmitting ?
Hi Guys,
I have an old Narco 810/Flightcom 403 combination that's worked well for almost 50 flights . Recently , I've started getting a buzzing noise while transmitting . Reception is 5/5 .
Here's what I've tried so far:
- Re-racked the radio and confirmed that that BNC connectors are mated properly . Did not actually check continuity .
- Turned one mag off at a time while transmitting . No change . Can a mag still make noise if it's not turned on ?
- Turned off internally regulated ND alternator . No change . Can an alternator still make noise if not supplying voltage to the bus ? Bearings etc ?
- Turned off all lights and other avionics . No change .
So , I've tried a number of things and am running out of ideas . I have made a few observations about when and how it makes noise . I have a CS prop and there is very little noise at 2700 but the intensity of the buzz increases and the frequency decreases when I lower prop RPM . Also on final with the power pulled back almost to idle there was very little noise .
A few thoughts for continued trouble shooting ......
-Try different MP with a given prop RPM . May indicate an ignition system link but I thought I ruled that out by isolating mags ...
-I'm wondering if the different RPM affect might have to do with a difference in the vibration frequency affecting a loose conection , wire , antenna etc .
I may try putting my hand under the panel to check for vibration and maybe dampen it if there is .
Any suggestions are appreciated ! Unfortunately I have to jet off to the Orient so I won't be able to try all your very helpful suggestions until the weekend . Ultimately I want to modernize my panel but I would like to get the present system back in order until I do.
Marc
1993 RV-4 C-GVMT
Formerly N144RS
SN 1444
Old 09-01-2010, 10:42 AM
fl-mike's Avatar
fl-mike fl-mike is offline
The mic input is a very low level signal, so it is likely that's where the noise is getting in.
Suggestions:
1. Try a different headset/mic.
2. Try the other input if you have it wired and a PTT.
3. Try going direct to the radio.
if 2 or 3 help, check the cable shield connections on the aircraft mic harness.
Check the mag wire shields.
If it's a RPM related whine, it is probably alternator noise. Mine failed at about 85 hours. Was still charging, but got a fault light and heard a whine only when transmitting. (unlike the constant whining I usually get from my passengers)
Good luck
Mike W
Venice, FL
N164WM
Old 09-01-2010, 11:43 AM
Dayton Murdock's Avatar
Dayton Murdock Dayton Murdock is offline
I had the same problem with my 403 intercom
I ran a new ground wire from the PTT switch to my radio ground and the noise is gone.
Dayton Murdock
VAF#408 RV4 N359DM Flying 1046 hrs 7/16/19
Builder Log
Old 09-01-2010, 12:55 PM
Some great advice so far . The noise not a traditional alternator whine but more of a low pitched buzz . Still happens with the alternator off .
I can easily try transmitting through the rear seat PTT . Didn't think of that one last night when I actually had another pilot helping troubleshoot .
Marc
1993 RV-4 C-GVMT
Formerly N144RS
SN 1444
