Old 08-31-2010, 06:32 PM
Alschief Alschief is offline
Default "T" MOD Service Bulletin for 032H2AD
Looking for a copy of the mod or link to it.
AL & Brenda Smith
RV12, UL Power N495BA Flying
RV6 N495AB Sold
KEOS Neosho, MO
alsmith@olemac.net
alsmith@ulpower.com
Old 09-01-2010, 10:57 AM
rjcthree's Avatar
rjcthree rjcthree is offline
Default T-mod
I've searched my lycoming CD for all T-mod stuff, and besided the parts list updates, the onls S document I can find is SI 1406B, which supercedes 1406A. It does not detail the repair, only the associated part numbers.
I'm using a H2AD -Tmod on my 9a. Mounted the engine Sunday.
If you want the actual doc, send me your email via im. Rick 90432
Old 10-02-2010, 06:04 AM
Default H2AD Overhaul
I am in the process of overhauling my engine. I am not going to do the "T" Mod. I am going to use 351C Lifters. Does anyone know why the lifter body has a flat ground into it? My guess is is for oil flow.
AL & Brenda Smith
RV6 N495AB Sold
KEOS Neosho, MO
alsmith@olemac.net
alsmith@ulpower.com
Old 10-02-2010, 06:59 AM
rjcthree's Avatar
Default 351c lifters
Since the lifter/engine design goes back to the mid-60's, I doubt you'll find the design reason here, maybe the hot rod groups?
Since you're not going T, you could use the Canadian roller lifter cam/lifters, which is stc'd in Canada. My case was already T, so I had no options.
Rick
Old 10-03-2010, 05:53 AM
Question T Mod
I am already commited to stay with the original design.
This will be the third run.
I have one other question.
When we received the case back from DIVCO, they had a bag with 5 pipe plugs, 4 each 1/8" and one 1/16".
The parts manual only shows 4 plugs which leaves one 1/8" extra.
Does anyone know where it should be installed?
We plan to cal DIVCO Monday if we can not resolve.
AL & Brenda Smith
RV6 N495AB Sold
KEOS Neosho, MO
alsmith@olemac.net
alsmith@ulpower.com
