Old 08-30-2010, 08:13 AM
Tom Martin Tom Martin is offline
Default Tip: Marking template
Here is a simple tool that I made to do some repetitive marking on the RV10 door window cutouts. This simple template takes minutes to make but can save a lot of measurements. It also removes measurement errors, which often happen when making repetitive marks using a ruler.
The small hole is where you place the pen, the large hole is so that you can see if you are actually making a mark. The large hole also helps to reduce the smudging that often occurs when dragging a pen in this kind of situation. The line helps you to visually keep the template 90 degrees to the surface. On this particular template I rounded the face so that it would go nicely around the smallest window radius.
Enjoy
Tom Martin RV1 pilot 4.6hours!
CPL & IFR rated
EVO F1 Rocket 1000 hours,
2010 SARL Rocket 100 race, average speed of 238.6 knots/274.6mph
RV4, RV7, RV10, two HRIIs and five F1 Rockets
RV14 Tail dragger
Fairlea Field
St.Thomas, Ontario Canada, CYQS
fairleafield@gmail.com
