I can't think of any reason why not to. That's the first step in building the leading edges and tanks anyway. The only thing I wouldn't do is try to drill the splice plate that goes between the tank and the LE to which you attach the platenuts. Having the LE tight down on the spar would probably give you more accurate results for that strip. Otherwise, I say go for it.
Also, if your plans are any like the -9's, I'd highly recommend riveting the LE before the tanks. It's kind of a "warm-up" for the proseal version you'll be doing with the tanks. Good luck.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
