Old 08-26-2010, 09:09 AM
prkaye prkaye is offline
Default MATCO axle and wheel balancing
2 questions:
1) After a bunch of reading I think I'm going to get the MATCO WHLAXLE24A, which sounds like an economical and convenient solution to the axle-preload problems with the standard nosewheel installation. Has anyone here with a side-by-side 2 seat -A Model added this axle to the standard MATCO nosewheel? PIREP?
2) In the MATCO installation instructions, they say you can balance the tire if desired, and show puttnig a 3/8 rod through the wheel and setting it up on two blocks. They just say "static balance as required". (http://media1.veracart.com/matco/ite.../document1.pdf) . They sell lead balance weights (MSCLDWT), which I guess your'e supposed to stick somewhere to balance the wheel/tires. My question - where does one stick these weights? I've never balanced any tires before...
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 08-26-2010, 09:11 AM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
Put the weights along the wheel part that is perpendicular to the tire....not the other surface that the bolts go through.
I have gotten weights from motorcycle shops
Suggestion: always balance your wheel/tire assemblies.
