Go Back   VAF Forums > RV Firewall Forward Section > Propellers
Old 08-25-2010, 01:32 PM
Janekom's Avatar
Janekom Janekom is offline
Question Advise on Sensenich wood prop needed
Helping someone with an RV6A, 200hp Lycoming and Sensenich wood prop.
The number on the prop is W71T5HMN-85G.
Can someone please help me with the torque value to use on this as well as a simple factor to use when using a crow foot on my torque wrench. As the nuts are on the back of the crank flange I cannot get in with a socket and will have to use a crow foot and I am of the opinion that the values will change.
Jan Hanekom
South Africa
Approved Person nr 325
http://www.rvbits.com
RV10 - ZU-XOX - (Flying)
RV7A - ZU-JRV - (Flying)
RV10 - ZU-JVR - (Written off)
RV7 - ZU-LOL - (Flying)
RV10 - ZU-RVI - (Flying)
RV7A - ZU-MER (Bought back)
RV7A - ZU-JAD (Sold Flying)
Dues paid for 2020 WITH A SMILE
Old 08-25-2010, 03:20 PM
RV8R999 RV8R999 is offline
I don't have my reference for the needed torque values but when using a crows foot as long as you orient the foot 90 degrees to the wrench you do not need a correction factor since the moment is the same distance from handle to center of rotation. If you orient the crows foot straight you'll need a correction which you can figure out by equating the ratio of torque/wrench length = corrected torque/(wrench length + crows feet length) and solve for corrected torque. Make sense? At least this is how I would do it...
Old 08-25-2010, 10:06 PM
Janekom's Avatar
Thanks Ken,
So with the standard crow foot, resembling a very short open end spanner with a square hole at the back, makes it a "straight orientation" and I will calculate the difference.
Jan Hanekom
South Africa
Old 08-26-2010, 04:44 AM
Yes Jan if you orient the crows foot in a straight line with the handle you'll need to calculate the new torque value. But if you install the crows foot such that its open face is 90 degrees to the handle no correction is needed. I try to use it in the 90 deg position more often than not.
Old 08-26-2010, 06:36 AM
WilburD2 WilburD2 is offline
Default Torque values..
Right out of good ole AC 43-13..
http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/0/99c827db9baac81b86256b4500596c4e/$FILE/Chapter%2007.pdf
Pgs 7 on has the answers about torques and formula's and such
Bill S.
A+P, RV Dreamer + Schemer
RV-9 preplans in hand
Old 08-26-2010, 12:56 PM
Janekom's Avatar
Thanks Bill - and it is sitting in my cupboard gathering dust
Jan Hanekom
South Africa
