I know this is an old thread, but I saw it when I was searching for something else.
VAN's aircraft are all low wing. Pickup truck beds are high enough to gravitate fuel to the tank.
Get one of those tiping barrel cradles. Fill and carry the drum upright, which is totally legal.
At your plane, thread in the grounded hose with control nozzle into the 3/4" NPT bung.
Tip the barrel & cradle to the horizontal (hose at the bottom) and start fueling. Slightly open the larger bung at the top to vent and break the vacuum.
If you fill less than 45 gallons, the top bung will be above the fluid level in the horizontal position.
Safe, cheap, legal.
Secure the drum in transit, have a fire extinguisher.
http://www.grainger.com/Grainger/DAY...m-Cradle-1GC91
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is
nothing-absolute nothing-half so much worth doing as simply messing around with
Aeroplanes
(with apologies to Ratty)
2019
