08-23-2010, 07:03 PM
Did the ability to burn auto fuel affect engine choice?
Of course Im thinking way far ahead... but I always imagined a 180hp (or 200 if I strike it rich!) fuel injected engine... Long story short, a friend is letting me fly his cessna 150, and paying HALF the price per gallon for auto fuel is becoming a bad habbit of mine. To the point where I cringe paying $3.80/gal for 100LL!
So my question is did this play into your engine selection? From what I have read so far... the only way I can do mogas is to get a D rated Lyc. O-360. Lose the fuel injection, and be happy with about 170hp...
08-23-2010, 07:20 PM
IO-375?
Injection and 197hp mogas / 210hp 100LL
08-23-2010, 07:44 PM
Daniel,
Definitely affected my choice. I got an 8.5 compression IO-360 Superior, which burns premium mogas. The state will refund my road use tax, so currently I'm paying maybe $2.90/gallon. With avgas around $4.50, and using 7 gal/hour, that translates to around $10/hour in savings. Buy two hours and get one free!
greg
Greg Arehart
N 7965A
08-23-2010, 08:09 PM
I opted for the AeroSport IO-375. I don't plan to run auto gas but I wanted to make sure I had the option more so because of the uncertain future of 100LL.
08-23-2010, 08:26 PM
Effected my choice
I got an aerosport O-360 wanting the option for mogas 8.5 compression. I dont know if I'll ever run mogas but I have the option.
Paul 'Bugsy' Gardetto, Col, USAF (ret)
Milwaukee, Wisconsin (Timmerman Field)
N377KG - Flying (250 hrs)
RV-7A, Aerosport O-360, WW200RV
Advanced Flight 5400
Avidyne IFD440
Paint by planeschemer.com
08-23-2010, 08:36 PM
engine choice
When I started looking for a "deal" on an engine, I would have jumped on the best deal as long as it would work in my -9A.
The "deal" turned out to be an o-320E2A 150 HP lyc. The fuel required is 80/87 so I think it'll run on regular mogas. 7:1 compression ratio.
As a matter of fact, I've been doing some ground testing using mogas. The engine seems to like it just fine.
With 100ll prices as high as they are, I'm not sorry I ended up with this engine.
Now I just need to figure out how to transport mogas to the airport
Dave
08-23-2010, 08:37 PM
I have a mogas burning RV now but like most men I am always looking on to the next and best thing. If I build an -8 it will have a mogas burning engine. If my -4 engine needs to be redone it will remain a mogas burning engine.
It's easy to find a local place that sells relatively cheap avgas but odds are it won't be your home field and it sucks having to stop to get gas on your way home.
Sid Lambert
RV-7 Sold
RV-4 - Flying - O-320 Fixed Pitch - Red over Yellow
08-23-2010, 08:39 PM
Stock Lyc IO-360 from Vans so I could run Mogas if needed but have no intentions of doing so at this time.
John Furey, RV7. Ohio
Life's Short...Fly Often!
08-23-2010, 08:42 PM
Sure it did
Bought brand new Lycoming with 8.5 compression.
08-23-2010, 09:46 PM
I have the same engine as Dave (but still in pieces) and was considering converting it to 160 HP (to match my used prop)... but that means the compression will be 8.5:1.
Will I be able to run mogas with that compression? It is about $1/gallon cheaper around here. As for ethanol, I've been able to confirm that my Andair gascolator, fuel selector don't mind it and I think the Facet pump and red cube will be OK too. That just leaves the engine driven pump and the carb itself....
Dave Gribble VAF #232
Building RV-9A N149DG (slider, IO-320, IFR)
Restored and Flying Beech Super III N3698Q
Marion IA
Struggling with fiberglass
There is no sport equal to that which aviators enjoy while being carried through the air on great white wings." Wilbur Wright, 1905
