Sorry guys! I guess I didn't fill you in on all the details.
Mattituck does NOT dyno each engine that gets tested in their cell. In fact, I don't even know if they HAVE a dyno. Needless to say I cannot give you a HP number. The engine is an ECi TMX IO-360 with a Superior FF Sump with factory compression. Pure and simple, kind of boring. It SHOULD produce 180 hp all day long. I think any man would agree that perhaps a couple of ponies are likely added with any EI system.
What I noticed:
- Smoother operation while in EI mode
- Fuel flow came down .5 gph when switched on but returned to previous after about 10 seconds
- Engine "jumped" when system came alive throughout all RPM ranges
- More noticeable changes at slower RPM's
- Should provide better starts
- It was fun to play with!
I do expect this to really pay off at reduced cruising RPM's at altitude and while running LOP.
I guess we will have to wait for that data and compare it to Darwin's results when we are both flying.
If there was anything I missed, ask away. I might have an answer for you.
I guess what it comes down to is any EI is better than a mag for all the same reasons. You need to make a choice based upon your needs, wants and budget.
I chose G3i because:
- G3i keeps the Slick mags
- Uses the MSD box that cars have used for decades
- Gives me 2 EI's in one box
- I like capacitive discharge systems (prior experiences)
- Price is good
- Thomas has designed a really good system for the MSD box
- The installation is simple
Can't wait to fly behind it!
CJ
