which FAB for AFP?
Another speed bump. The AFP injection system on my IO-320 doesn?t even remotely line up with the scoop on the bottom of my cowl. The inlet of the injector is basically in line with the scoop inlet, but several inches too high. If i look into the scoop i can see the bottom of the injector. I was planning on fabbing up a new scoop anyway, but now I am wondering how i can put a filter on the front of the AFP? Any thoughts?
Rob
Rob Holmes
www.myrv3.com
N59LG
The minimum number of planes one should own is one. The correct number is n+1, where n is the number of planes currently owned. This equation may also be re-written as s-1, where s is the number of planes owned that would result in separation from your partner.
- Veluminati
