Old 08-21-2010, 11:09 AM
chepburn's Avatar
chepburn chepburn is offline
Default Tool to torque bottom engine mount nut on dipstick side
Never mind.....
Managed to get the box end of the stubby on. Thanks... Just dont like torquing from the bolt side
Hi all...
What tool did you use to get a good grip on the bottom engine mount nut thats by the dipstick on #3 cylinder of an IO-360? A stubby 5/8 socket doesnt fit..the casting is in the way, a stubby 5/8 barely gets onto the flats.
The nut is on, and torqued, but not to the spec value...and I need to take it off again to remove a washer so the cotter pin will fit properly. Im not too keen on torquing it with the stubby barely contacting the flats.
Any hints?
Thanks in advance.
Chris Hepburn
Ottawa, ON
RV-8 C-GOGO FLYING
Renew 12/20
