Old 08-20-2010, 07:01 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Default O-360 Backfiring and Low CHT
OK, here's a puzzler for the peanut gallery....lookign for ideas!
Louise aborted an evening flight today after noting considerable backfiring at low RPM's, accompanied by both a very low CHT AND EGT on #2 Jug. I ran it and confirmed the situation. AS I ran it up, the temps came up, but stayed power than the other cylinders. Mag check was OK - a bit rough, but no significant differential drop. I believe that I have noted a slight increase in backfiring as Louise taxies in from her daily commute the past couple of weeks, so the problem may have been progressive.
We pulled the cowl - compression check was good, no difference between it and the other cylinders - 72 or 74 over 80, not terribly hot. Upper and lower plugs were very clean. Mag timing is perfect. Checked all the plug wires and Magneto caps - there were fine. Pulled the rocker box cover, and nothing is amiss under there. No apparent leaks (exhaust, oil, or other) from the jug. About the only thing I haven't done is replace the intake coupling tube/hose - might be an intake leak, and the hoses are all pretty old. I tightened up the hose clamps, but don't have any spares to test by changing them out.
Before I try and find some intake couplings, anyone else have any ideas?
Lycoming O-360-A1A, stock carb, mags, nothing unique.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 08-20-2010, 07:10 PM
rbibb's Avatar
rbibb rbibb is offline
I'd suspect the intake tubes lacking any other obvious issue. A leak would screw up the mixture on that jug and maybe lead to the problem.
Steal one off your other plane and check it out.
Some Lycoming expert may have a better idea....
Richard Bibb
RV-4 N144KT
Fredericksburg, VA
KEZF
Old 08-20-2010, 07:18 PM
John Clark's Avatar
John Clark John Clark is offline
Default Intake leak
I'm voting for an intake leak, one cylinder only and the symptoms indicate lean.
John Clark ATP, CFI
FAA FAAST Team Member
EAA Flight Advisor
RV8 N18U "Sunshine"
KSBA
Old 08-20-2010, 07:22 PM
aerhed aerhed is offline
Could be a sticky valve my friend. They stick, they unstick, then stick again. Not sayin' that's it for sure, but if you don't find something else, maybe try a rope trick. Unspring the valves & operate the valves by hand. If they are leaded, you'll be able to tell. If they were bent or burnt, you wouldn't get compression.
Old 08-20-2010, 07:30 PM
AltonD's Avatar
AltonD AltonD is offline
I vote for the intake leak. I saw the same thing, only difference, the leak was not on the odd ball cylinder, it was on another one.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 08-20-2010, 07:42 PM
az_gila's Avatar
az_gila az_gila is offline
Smile An intake leak...
...or valve sticking...
From Sacramento Sky ranch...
14. Sticky valves. Occurs most frequently in the hot summer months. Frequently occurs on the first start of the day when the engine is cold. Remove rocker gasket. Turn engine backwards until valve is fully closed. Using both thumbs, depress valve springs. Valve should open and close without any feel of dragging. Valve movement should be smooth.
Time to perform the SB 338 valve wobble test...
http://www.lycoming.textron.com/supp...dfs/SB388C.pdf
Has it been hot in TX recently...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 08-20-2010, 08:07 PM
vic syracuse vic syracuse is offline
Super Moderator
Paul, I agree that most backfiring at LOW rpm's are the result of sticking valves. Intake leaks usually are recognized by higher CHT's at higher rpm's.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Old 08-20-2010, 08:14 PM
SI-1485 might help in determining if the wobble test is necessary.
http://www.lycoming.textron.com/supp...fs/SI1485A.pdf
FWIW, my nearly new engine backfires on occasion at idle power in the traffic pattern. I've about concluded it is normal, but who knows? Engine seems to run fine otherwise.
dd
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 08-20-2010, 08:54 PM
az_gila's Avatar
Smile Yes and no...
dd
...my Tiger O-360 engine needed a TOH at 600 hr - on Lycoming rebuild with new cylinders with the hi-chrome guides - so the 1000 hr first check recommendation is not very foolproof.
If you have the correct Lycoming tool, it is pretty non-invasive if you check the guides only and don't clean the lifters. The valve springs do not have to be removed with the correct tool - but if you have the AC Spruce tool, then the valve springs do need to be removed...
Gil Alexander
Old 08-21-2010, 06:26 AM
Ironflight's Avatar
Great ideas folks - I hadn't thought about sticky valves (even though those used to be discussed all the time in the Grumman world, as Gil well knows) - I'll look at that this morning.
Paul
Paul F. Dye
