Old 08-20-2010, 02:06 PM
Jess Baker Jess Baker is offline
Default Rubber Molding Tip Up Canopy
I'm looking for any suggestions for the replacement of the rubber molding on the tip up canopy. I have a 1992 RV6 and the molding that is located on the top of the fire wall that the canopy rests on when closed is in bad shape. It's either missing portions of it, or breaking down. I have looked in the Van's catalog, but could not locate any replacements. Any suggestions would be greatly appreciated.
Jess
Old 08-20-2010, 02:28 PM
RV7Ron's Avatar
RV7Ron RV7Ron is offline
I'm not familiar with those seals, but check McMaster Carr...
http://www.mcmaster.com/#buna-n-rubber-seals/=8hn2j6
Ron Duren
Mechanical Engineer
"SportAir PhD"-RV Assembly/Composites/Electrical
Denver, CO (KBJC)
RV-7 'Tip Up'
Flying!! as of 3/16/14
IO-375/WW 200G-CS/SkyView/Dual P-mags
N531R "Wablosa" Wings of Red
http://www.ronsrv7project.blogspot.com
Old 08-20-2010, 02:37 PM
rich rich is offline
Default canopy seal
Jess,
Van's on line accessory catalog has 2 items in the MISC STUFF. Not shure which one is the front seal. I think its the P-Strip. You might call and confirm or someone can chime in.
http://www.vansaircraft.com/cgi-bin/...e&product=misc
Rich Rudolph
VAF#007
RV6A 2000 HRS.
Fort Worth,Tx.
Wright Brothers “Master Pilot” Award
Old 08-20-2010, 05:06 PM
Norman CYYJ Norman CYYJ is offline
Go to your local hardware store and look at their selection of sealing strips for doors and windows. That is where I find replacement seals.
Old 08-20-2010, 06:51 PM
apkp777's Avatar
apkp777 apkp777 is offline
I got some from Home Depot. Works good so far.
Tony Phillips
N524AP, RV 9 (tail wheel)
Old 08-23-2010, 03:13 PM
Default Molding-Tip Up Canopy
Thanks everybody for the quick replies and suggestions. That works.
Old 08-23-2010, 04:37 PM
az_gila's Avatar
az_gila az_gila is offline
Smile Vans sells...
...and shows a S88D20 seal on the plans (Vans part number S88D20X60)
It is not the "P strip" that the aviation department of Home Depot sells - it might be better described as teardrop shape.
This shows it better - it is a much thinner material than the P strip, and I believe is more compressible.
Page link if pic does not work...
The part number came off a RV-7 plan, IIRC the RV-6 initially used a "V" shaped rubber here, but I can't find the reference at the moment. (found it - see later post)
This is the Aircraft Spruce (and HD) P-strip, at 1/4 inch thick -
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 08-24-2010, 01:14 PM
mike newall's Avatar
mike newall mike newall is offline
Just got this - looks really good and the adhesive is very, very sticky !
http://www.flyboyaccessories.com/sto...roducts_id=192
Old 08-26-2010, 09:33 AM
Snowflake's Avatar
I just worked on this problem myself, and tried three different profiles from McMaster:
1129A95 - D-shaped profile, adhesive backed
1129A964 - P-shaped profile, adhesive backed
12335A43 - D-shaped profile, self-clamping
By far, I liked the 12335A43 the best. The only catch is, when compressed it's still a tiny bit too thick for the gap, and my canopy latch doesn't fully close. I tried a peice of it and removed it, then tried the 1129A95 D-shape. It fits better, but I still may need to adjust the fit of the latch. I haven't flown with it yet, but it does seem to close off all gaps, and still has some play left so when the canopy gets lifted in flight (it raises a bit due to air pressure) it should still seal.
If I do decide to adjust the latch mechanism to give more clearance, i'd be inclined to just go back to the self-clamping one though. I'm adverse to adhesives, as they always seem to age funny and you end up with pieces of weatherstripping peeling off in the heat. The self-clamping one just grabs the inner flange of the canopy, and fits quite nicely (everywhere but the very back corners, that is).
[edit] Just looking at McMaster right now, I found a 1/2" by 1/4" seal that looks like the one Gil recommends above. It's p/n 1067A3.
Rob Prior
Old 09-04-2010, 11:23 AM
az_gila's Avatar
Smile The original seal...
...shipped with the -6 kits was a V-shaped seal... my pic -
I guess the idea was that the tip-up rested firmly on the metal bukhead, and any air getting through opened up the "V" to create a seal.
I believe it is similar to this Spruce part, but seems a bit better formed --
http://www.aircraftspruce.com/catalo...ges/vstrip.php
Spruce's pic -
Does anyone know the history on this seal, and why Vans changed to the other seal shown above for the later -7 (and -9, I presume) kits?
The "V-seal" would seem to put less force on the lip of the tip-up, and thus enable it to fit into it's original, non-sealed location better.
Was the original "V-seal" not effective?
Anyone flying a -6 with this "V-seal" and can report?
Gil Alexander
