throttle bracket guidance
All, I'm finalizing my H2AD/Ellison setup (at least version 1.0) and I'm building a mixture bracket. It will be two L's of 0.040" 2024 sheet, 1"+ legs, nested and riveted. It will bolt in with two through the sump bolts (just like eveybody else with an H2AD). It should be clean and simple. Any reason something simple like this is unacceptable? The cable housing is going to be tied pretty close, but not too close - loads will be modest. THoughts?
Rick 90432 (9A, 320-H2AD, Ellison)
