Old 08-18-2010, 01:58 PM
PCHunt PCHunt is offline
Default Brake Reservoir
Has anyone ever seen or used a transparent brake fluid reservoir? I'd like to be able to see the fluid level.
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2020 Donation+, Gladly Sent
Old 08-18-2010, 02:09 PM
RV8RIVETER's Avatar
RV8RIVETER RV8RIVETER is offline
Matco makes one. I bought one, but decided to go with the individual reservoirs on the master cylinders.
I you want a good deal on it give me a PM.
Wade Lively
-8, Flying!
N100WL
IO-360A3B6D, WW 200RV
Old 08-18-2010, 02:10 PM
roee roee is offline
Matco has one: http://www.matcomfg.com/Reservoirs-tp2-9.html
Roee Kalinsky
San Diego, CA, U.S.A.
RV-7A under construction
www.kalinskyconsulting.com/rvproj/
Old 08-18-2010, 08:19 PM
gasman gasman is offline
Go to your local motorcycle shop and take a look at the many kinds that they use.
Old 08-19-2010, 05:32 AM
pierre smith's Avatar
Default Even cheaper...
...my Air Tractor uses an old VW Beetle clear plastic reservoir from the factory, mounted on the lower instrument panel, so you can see it in flight even
Go visit a junkyard,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
