Old 08-18-2010, 05:47 AM
grubac grubac is offline
Default aluminum bulkhead fitting
Hey Guys
I've been trying to get information about the aluminum bulkhead fittings offered by Van's. The part number is EYEBALL SE961-125B.
My firewall is quite thick - 10mm - and I'm trying to determine, before buying it, whether or not this fitting would be appropriate for a thicker firewall like mine.
Anyone have any experience with them?
all the best
grubac
Old 08-18-2010, 12:58 PM
Greg Arehart's Avatar
Grubac,
I've installed a couple of these on my firewall. The concern I would have is the thickness of your firewall, because the brackets that hold the sphere in place are machined (well, stamped) to fit the sphere with a minimum thickness of firewall. A 10-mm firewall will make the sphere pretty loose, I would think. You might get away with 5 mm.... but the only way you will really know is buy one and try it.
greg
Greg Arehart
N 7965A
Old 08-19-2010, 02:52 AM
Thanks for the response Greg
That's exactly what I was concerned about. I figured those sphere-holding plates wouldn't grip it as well if the firewall was thicker than usual.
I'll have to look for a better option.
all the best
grubac
