Old 08-16-2010, 01:30 PM
flickroll's Avatar
flickroll flickroll is offline
Default GoPro Camera Mount
What type of mount is being used with this camera? I am considering one for my RV-8 but don't see a good mounting option for the -8. Thanks
Jim Shannon
RV-8 N52VV
Charlottesville, VA
AFS 4500 EFIS & 3400 EFIS/EM
G430W - SL30 - G327 - G696 - G240
TT DigiFlight II VSVG w/pitch autotrim
VP-X Pro
Old 08-16-2010, 02:48 PM
kevinh's Avatar
kevinh kevinh is offline
I have one on the way. I'll let you know what I find.
The places I'm going to try:
  • Mounting to the wingtip with a couple of the screws
  • Mounting to the VS with a rivnut
  • Mounting to the RV7 slider rollbar
  • Mounted behind the pilot with a Gorilla Grip
-kevinh, Track my RV-7A, flying, alas, sold in 2013 after 450ish hours. (I'm now building something different)
Old 08-16-2010, 04:21 PM
Capflyer's Avatar
Capflyer Capflyer is offline
Default Suction Cup Mount
I use the suction cup mount attached to the inside of the canopy and it has been working great.
Mike
JAMES AIRCRAFT.com
Flying - RV8 Hot Rod "Drone Killer"
Flying - RV8 "Look'n Good"
RV4 - FAST & FUN! Rebuilt, Flown, Sold
RV-7A Built, Flown, Sold
Old 08-16-2010, 06:26 PM
Jim P's Avatar
Jim P Jim P is offline
Any thoughts if that suction cup will eventually cause plexi cracking? I was looking at the same thing for a ContourHD.
Jim Piavis
RV-7 (Flying!)
http://adap.com/rv7
Redmond, WA
Old 08-16-2010, 06:43 PM
Tim 8-A's Avatar
Tim 8-A Tim 8-A is offline
I have mine mounted behind the passengers head on the canopy slide, I used a supplied mounting pad, Here is a (long) video for example.
http://www.youtube.com/watch?v=0s89gU4FUqU
Tim Blake
Colleyville, Tx
RV8a Purchased flying (many changes) Sold
RV-10 Purchased flying.. Panel upgrade complete.
G3X/Dynon/TT
All new interior complete.
Flyin like a dream.
Old 08-17-2010, 04:51 AM
Capflyer's Avatar
No troubles so far and it's been attached for about 50hrs of flying with no rings or scratches. What I really like about the suction cup mount is the ability to move it to different places with ease.
Mike
JAMES AIRCRAFT.com
Old 08-27-2010, 05:19 PM
flickroll's Avatar
I never could get any of the GoPro mounting devices to provide a good mounting solution. So here's what I bought from Amazon:
GoPro Tripod Mount for HERO Cameras
RAM Mounting Systems RAP-B-166-2U Composite Suction Cup Mount
RAM Mounting Systems RAM-B-202AU 1" Rubber Ball Base with 1/4"-20 Stud For Camera
This gives me all kinds of different angles to play with when I mount the camera to provide the view I desire. I have not yet tried it in flight but it seems sturdy on the ground.
Jim Shannon
RV-8 N52VV
Charlottesville, VA
VP-X Pro
Old 08-28-2010, 03:03 AM
flyvans.com flyvans.com is offline
i'm using the suction cup mount to the inside canopy so far.
however, IMHO due to the relatively long distance from the base and through 2 joints, the vibration of the canopy transfers to the cam quite a bit...
whether that affects the video quality very much is not so clear yet.
will try alternate methods and will also try to get dynamic balancing done once in a while.
rgds, bernie
p.s. already at 11 successful flight hours :-)
Bernie Daenzer, Alex Lichtensteiger
www.flyvans.com
RV-7A
S/N 72072, Flying!
HB-YMT (Switzerland)
Old 08-28-2010, 03:57 AM
flickroll's Avatar
I'm going to try my Ram mount contraption on the inside of the windscreen which I hope won't transmit as much vibration as the sliding canopy. That's my story and I'm sticking to it
Jim Shannon
RV-8 N52VV
Charlottesville, VA
VP-X Pro
Old 08-28-2010, 07:56 AM
777drvr 777drvr is offline
Default How about outside ?
I assume that only inside mounting solutions have been discussed so far ? How about vantage points on the exterior ? I wouldn't trust just the tape mounts or the suction cup . I was going to make an aluminum mount for mine .
Marc
1993 RV-4 C-GVMT
Formerly N144RS
SN 1444
