Old 08-16-2010, 01:12 PM
Veetail88's Avatar
Veetail88 Veetail88 is offline
Default Rear spar trimming
For all you structural engineering types,
After having drilled my rear spar attach holes, jazzing one up and applying the fix from Van's, I now have a problem where the rear spar sticks down too far to allow the belly skin from smoothly tansitioning to the bottom wing skin.
Uploaded with ImageShack.us
So I'm wondering if I can trim the bottom of the rear spar to allow the transition as long as I maintain minimum edge distance to the rear spar attach hole?
What do you think?
Jesse Bentley
N229Z - RV-8 - Flying - Livin' the dream!
Old 08-16-2010, 08:40 PM
I think this one is worth a call to Vans regardless. It might be fine, but there is certainly a limit to my willingness to do garage engineering. Unfortunately, I did not stay in a holiday Inn last night, so I can't help.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
Old 08-17-2010, 08:39 AM
Veetail88's Avatar
Default Word from Van's
Just got a word back from Van's on this.
Scott says as long as the 5/8" edge distance is maintained, I'm good to go.
Jesse Bentley
