Fuel Pump and Gaskets?
Ok, so I have to admit I no hardly anything about engines. I am going to take the engine off the mount next weekend. I did not install the oil pressure fitting properly and need to redo it. While I'm at it, I want to do three other operatons - put a heat shroud on the fuel pump, install a 90 degree oil filter assembly and spacer and install an auxilary alternator on the vacuum pad. Questions I have;
Fuel pump - this is a new Lycoming O-360. Do I need a new gasket or can I use the exiting one? If new, where do I find one qucikly?
All other: Gaskets? Installed dry or with some addtional sealent. What is the rule here when installing gaskets and does it change depending on the item under consideration?
Assistance appreciated.
Thank you.
John
John Volkober
RV-9A
Camas, WA
