Old 08-15-2010, 11:15 AM
tturner tturner is offline
Default Harbor freight inspection camera ?
Harbor freight has a wireless inspection camera on sale for $89.99.
http://www.harborfreight.com/wireles...tor-66550.html
Does anyone have experience using this to borescope aircraft cylinders? If so are you able to get the camera head thru the spark plug hole with the mirror attached? How was the picture quality and ability to focus in the cylinder and see the valve heads? Are there better solutions than this product in the under $300 category?
Tommy Turner
Fayetteville GA
RV-4 sold
RV-6 sold
RV-8 Flying
RV-14A building
Old 08-15-2010, 11:24 AM
PCHunt PCHunt is offline
That looks very similar to the HF one that I tried. The head was too big to go through the spark plug hole on mine.
I returned it.
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2020 Donation+, Gladly Sent
Old 08-15-2010, 11:39 AM
Tony Spicer Tony Spicer is offline
Heres a customer review:
"The down side is that the dia. of the camera head is 18 mm and will not fit down the standard automative spark plug hole. This is another application I bought this camera for but was not able to use for that need. If they offered a 9mm camera / cable attachment (which will fit through a spark plug hole) as an option they would sell thousands more. The OEM manufacturer of this camera does make this 9MM cable option for this camera but apparently it is not made available to HF. Too bad."
Might be worth the trouble to chase down the 9mm cable.
Tony
Old 08-15-2010, 12:19 PM
Mel's Avatar
Mel Mel is offline
I have one and like it very much. Yes, it is too big for cylinder bore-scope, but there are many other places it comes in handy for inspections.
Side note: If you carry it on the airlines, you will get to meet TSA personnel. Especially at DIA.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 08-15-2010, 01:11 PM
cfiidon's Avatar
cfiidon cfiidon is offline
Default RIGID
I bought a Rigid scope a couple of years ago and popped for the additional smaller head. I used it to scope the cylinders in my IO-550 and it worked fine.
But you do need the smaller head.
Don
RV-8 QB Titan ECi 191HP XIO-360
WW200RV Dynon D180 HS34 AP74
GNS430 SL30 GTX327 PS8000B Uavionix Echouat
"Pilots are alchemists... we turn gold into lead."
Old 08-15-2010, 07:17 PM
Doug Rohrer Doug Rohrer is offline
Thumbs down
I bought this tool and tried it out on my Lycoming O-320. The head will fit through the spark plug hole with just a little filing on a small protrusion on the camera. However, the mirror attachment makes it too big to go through. Also, the focal length is fixed at a distance too long to allow clear pics inside the cylinder. Save up and buy a real borescope.
Old 08-16-2010, 01:44 AM
SabreKGB SabreKGB is offline
I bought this exact one at Harbor Freight and promptly returned it the next day.
Getting a clear picture is near impossible and the quality is about what you'd expect from the price. A blur is all you'll get if you try to scope anything with this piece of junk. I thoroughly recommend not buying it, and if you do, save your receipt!
