Old 08-14-2010, 01:19 PM
Camillo Camillo is offline
Default I need advice on epoxy and fillers
Hallo. I am completing my fiberglass parts and wanted to know how to finish them.
I layed several layers of fiberglass and now would like to fill the medium areas and then fill the small holes.
From a different thread, I understand that I have to fill the first with flox and the latter with SuperFil.
My question is: since I also have "Quick Fair Epoxy putty" http://www.aircraftspruce.com/catalo.../quickPoxy.php , what this is for? Spruce places it among the "epoxy" but from the description it seems like the SuperFil.
I used Quick Fair fro empennage fairings. Do I have to use it also for canopy rear skirt or it is preferrable to use SuperFil?
Thanks.
Camillo
RV4 IO-320, Catto 3-blade, Christen, I-BILT
Flight time: 1 hour
Status: test flights
www.rv4.it
ROME, Italy
RV9A O-320 D1A, Hartzell C/S prop, slider, I-PRCA
Flight time: 350 hours
Status: SOLD
http://nuke.rv9.it
Old 08-14-2010, 01:40 PM
N941WR's Avatar
N941WR N941WR is offline
I don't think you want to use Flox, micro balloons maybe, but not Flox.
One trick that seems to work well is to put just pure slow hardening epoxy on and wait some time and then come back and using a squeegee, press it in to the holes.
Of course you will want sand the fiberglass first, to open up any holes you might have.
Best of luck.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 08-14-2010, 03:00 PM
Jkkinz's Avatar
Jkkinz Jkkinz is offline
Quick fair appears to be epoxy already mixed with microballoons. You mix the two parts together and squeegee on the part, then sand. If you already have the west system epoxy and a bag of microballoons you can just mix up your own paste.
Flox is used in structural applications. An example is if you need to lay glass into a 90 degree angle. You mix up the flox/epoxy paste and fill the corner. Then you would lay the glass over it and make a radius instead of a sharp 90 degree angle. The radius makes the angle much stronger than a sharp angle would be.
Microballoons are used more as a filler because they are very light and easier to sand. An example is a part that has low spots or a rough surface. You mix up the paste and spread similar to how you would spread bondo type fillers. Once it sets you can sand it
Jim Kinsey
7A Finishing and Engine
AFS screens
IO360A1A, Catto 3 blade
N527K reserved
Donated thru 2018
Old 08-14-2010, 04:56 PM
Another product worth mentioning is West System's fairing powder. It mixes with epoxy and is easier to sand than microballoons, at least in my experience.
Old 08-14-2010, 08:16 PM
DanH's Avatar
DanH DanH is offline
http://www.vansairforce.com/communit...ad.php?t=22931
Dan Horton
RV-8 SS
Barrett IO-390
Old 08-16-2010, 12:28 AM
Thank-you. I hope I have understood.
SuperFil is a good product. I am just applying it over the cured fiberglass.
Today, I will sand it and pass a pure epoxy layer.
QuickFair should be a similar product, but I am using SuperFil only, just to be sure.
Flight time: 1 hour
www.rv4.it
ROME, Italy
Status: SOLD
http://nuke.rv9.it
Old 08-16-2010, 01:53 AM
chris mitchell chris mitchell is offline
Default West system guides
The West system guides are very good - give lots of information on how to use the different types of fillers to best advantage.
http://westsystem.com/ss/use-guides/
Being an ex (amateur) boat builder I used these products as I was familiar with them and in the UK its easier to find marine suppliers than aviation suppliers.
I think Dan H's work looks really exceptional and I have learned a lot about epoxy work from his posts.
Chris
Old 08-16-2010, 08:17 AM
rv9aviator rv9aviator is offline
Morning Dan, quick question. I have West Systems 410 microlight fairing filler. Is that a product that can be used instead of micro balloons or are they for different purposes?
Jim Wright
RV-9A N9JW 90919 SoldArkansas
http://www.jimsairplanes.com
_______________________
"It's a brutal struggle for the biscuit."
Old 08-16-2010, 08:46 AM
DanH's Avatar
Jim, I've never used any of the West fillers, but yes, 410 looks like an expensive substitute for micro.
Dan Horton
RV-8 SS
Barrett IO-390
Old 08-16-2010, 09:07 AM
And the operative word is expensive. That's the info I was looking for. BTW the 410 works great and sands like easily. Thanks for the help, Dan. After reading all the posts you and Darwin put on the VAF I tackled my Horizontal stab tips. I taped the seams over the pop rivets and faired them in. It worked better than I ever thought it would. I have them primed with epoxy primer and you would think it is all one piece. Again many thanks for taking the time to help your fellow builders.
Jim Wright
