08-13-2010, 10:32 AM
Bend it or Rib it
What did you do on the elevator tirm. I have read so much about trouble here. and I am here.
08-13-2010, 10:37 AM
you can try to bend it first. If that doesn't work, then you can cut off your bends with a dremel and rib it the second time around.
I do think the rib is a more elegant solution to closing the ends on the tabs.
08-13-2010, 10:38 AM
I did a rib on the inboard end because on the early kits, the control horn was riveted to the end. I made a rib and set it back enough that the horn ended up flush with the end of the tab.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
08-13-2010, 11:37 AM
Originally Posted by Phil
you can try to bend it first. If that doesn't work, then you can cut off your bends....
Bret,
I agree with Phil. This is an area of assembly that seems to have gotten a bad rap. I really don't know why that is, but then using a simple block of wood my efforts at success are two tabs out of two. I suggest you try bending the tab exactly as Van's suggests. Then, if you do mess it up, the poor bend can always be cut away and the tab modified as Phil suggested.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
08-13-2010, 12:18 PM
I bent mine, but if I ever have to do it again I'll rib it.
08-13-2010, 12:59 PM
The rib method.
I'm a sheet metal person by trade, and couldn't get it to fit into my 4 or 8' sheetmetal brake.
L.Adamson -- RV6A
08-13-2010, 01:08 PM
My Vote is Bend It
I bent mine also and I'm happy with how both ends turned out. Just carefully follow the directions and take your time.
RV-7A
Empennage done, just starting on wings
Mission Viejo, CA
http://www.johnsrv7a.wordpress.com
08-13-2010, 02:21 PM
Rib here
I ribbed mine after I cracked it, the crack extended into the skin (scrap that one) and the second one turned out bad (again I was bending).
I'm not really happy with the one I made so I still plan on redoing it down the road, but this one is going flying. That'll be an easy side project after phase one.
08-13-2010, 02:29 PM
Bent mine and very happy with the result. My friend has used a rib and I don't think it looks as good, by hey I am sure he doesn't think so
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
08-13-2010, 02:56 PM
Darn. I was looking for one way or the other, I gess I will try bending and hope for the best. I oak hard enough?
