08-12-2010, 12:41 PM
Folding wingtips, keep an open mind
Has anyone ever heard of folding wingtips? Just the fiberglass portion.
With careful measuring, the RV-7 will fit in that extra space at the end of a row of T-Hangars, except for a few inches on each side of the wingspan. By being able to put them on a hinge of some sort, and leaving the spars in tact, I can slide it right into the tiny hangar.
This would bring hangar rent down from $295 to $30 per month. A huge savings in rent.
Anyone heard of this? think it is feasable?
Rick from Fresno
RV-7A
The art to flying lies in learning how to throw yourself at the ground and miss.
08-12-2010, 12:53 PM
I don't know about it from an engineering standpoint, but I really like the creativity of the idea.
More feasable would be choosing to own a 6A instead of a 7A. The 6A has a span about 2 feet less.
Also a small help would be to use teh horner style tips instead of the sheared tips. I think they are a couple inches narrower.
Scott McDaniels
Hubbard, Oregon
08-12-2010, 12:59 PM
Make em easy to remove by using hinges like on the cowl....
Several guys have started using hinges to attach their wingtips. Makes em easy to pull and remove....
08-12-2010, 01:00 PM
What if you were to just eliminate the Tips all together and just cap the wing off.
-david
08-12-2010, 01:03 PM
Done that
-david
I did that and the plane is about 2 kts slower.
Bob Axsom
08-12-2010, 01:12 PM
Not bad :
+ $265 = - 2knts...
Bob Hassel
NM
Subscription Paid for 2020
Home is where the hanger is...
08-12-2010, 01:43 PM
Originally Posted by bhassel
Not bad :
+ $265 = - 2knts...
Well, ...
I have to admit, if I could save $265/month by removing the wingtips, then I would remove the wingtips even if it costs two knots of speed.
But an alternate approach may be to install removable wingtips. That is what I plan on doing, and there is at least one company out there that sells a product for making the wingtips removable.
08-12-2010, 02:06 PM
I sincerely hope that you will ALWAYS have 2 people there then pushing in and out. With this kind of clearance, you're just asking for a "dinged" wing.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
08-12-2010, 02:10 PM
I have that kind of clearance in my hangar (we keep two planes nose to nose in a T hangar). We solved the 'ding' problem by building small railroad tracks for sliding the plane in - the tracks guarantee we can't hit anything.
