Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
  #31
Old 01-03-2011, 06:49 PM
1rv6flyer 1rv6flyer is offline
Mike,
Where is your iPad mounted? Can you post a pic of your iPad mount?
Thanks!
--Larry
Originally Posted by mrreddick View Post
I pulled my 2000C off it's RAM mount last Saturday and installed a 32GB IPad 3G, much easier to see with my old eyes! The terrain card that I purchased from LEI a few years ago is only 32mb. I believe at the time I got it there was an option for a 1Gb card for something like $99. What a ripoff!
Larry Mersek N336RV
Mountain Ranch, CA.
(KCPU) RV-6 flying
Old 01-04-2011, 06:37 AM
tcoldenhoff tcoldenhoff is offline
Default Card size and missing Luke SRA
I just received an update SD card in the mail.
The card is a 1GB SD card, but only has about 380MB of data on it, of which 310MB looks like terrain data. So that leaves 60% of the capacity free.
I have been very anxiously awaiting an update since early last year when Luke AFB had their "special rules area" turned on. Well, unfortunately, with the new update the Luke SRA does NOT appear to be depicted on the map. I have been through every map option and detail category there is to no avail.
Anybody know if I am missing something obvious before I go pursue their tech support?
BTW, I am using a Lowrance 1000.
Thanks.
Tim Coldenhoff
http://www.deru.com/~rv9a
Old 01-04-2011, 07:11 AM
mrreddick mrreddick is offline
Super Moderator
Location: Hangar/home at Hicks Airfield (T67), Fort Worth, TX
Default IPad Mount
Originally Posted by 1rv6flyer View Post
Mike,
Thanks!
--Larry
Larry,
Check out the Picasa link. It's very sturdy. I purchased it from www.gpscity.com
http://picasaweb.google.com/mrreddic...95245665844738
Mike Reddick
VAF#153
Pilots N Paws Pilot
RV6A N167CW 1,900 HRS
Ft Worth, TX (T67)
Old 01-04-2011, 08:54 PM
Thanks Mike, the iPad sure takes up some space on the panel! It looks like the ram mount is bolted to your panel making for a solid mount.
--Larry
Larry,
Larry Mersek N336RV
Mountain Ranch, CA.
(KCPU) RV-6 flying
Old 01-05-2011, 09:32 PM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
The acronym may be SATR. Here is some info
http://download.aopa.org/epilot/2010/101006luke.pdf
When I get my new 430W update I will see if it shows up. Looks busy in that area.
Old 04-14-2011, 10:45 AM
n504tw's Avatar
n504tw n504tw is offline
Default Jeppesen updates for the AirMap 500, 600, 1000, & 2000c
Jeppesen updates for the AirMap 500, 600, 1000, & 2000c will only be available through July 2011.
If anyone is looking for a Lowrance database update, now is the time to do so.
Gary Hall
F1 Rocket Evo under construction
Track Links: APRS
Old 04-14-2011, 10:47 AM
Ron Lee's Avatar
Thanks Gary. I was planning on doing it soon since my home airport ID changed so I better do it ASAP.
Database update ordered.
Old 04-20-2011, 09:28 AM
Ron Lee's Avatar
My update arrived 19 April. Put it in and checked to see if our airport ID changed from 00V to KFLY.
Odd. 00V is still there. Looks like KFLY may be there but there is a boxed X over it. Scroll in just the right place and I can see KFLY.
This morning I deleted all my flight planning routes that contain 00V and recheck. 00V is gone. KFLY is there with no X. Everything is fine.
Old 04-21-2011, 07:00 PM
Thanks, Tim, for confirming it's a 1GB card that ships with the Jepp update. I don't have terrain on my 2000c so if I bomb off the terrain files I'll still be able to get all my topo map data on the card. This is good. This is very good indeed!
Old 05-03-2011, 01:00 PM
I've been searching the Lowrance (LEI Extras) website and have found nothing other than fishing hotspot datacards. YUCK! Not sure but suspect this might come as a result of me being based in Canada.
Does anybody happen to know the part number for the aviation database update? Please, pretty please, will you share that info with me?
