my wings were packed together
in one crate. right on top of each other with a big sheet of styrofoam in between and a little on the side for padding, nothing more. The ailerons and flaps were removed of course, same goes for the tips. I have two pictures that will show how the crates are constructed (kinda from a distance) but it goes beyond my tech level to figure out how to post them. Send me a PM or something if you like...
I think the walls were made of two 16" planks stacked on top of each other and held together by pieces of 2x4. the top and bottom were big multiplex sheets reinforced again by 2x4.
However, I just build a rather sturdy cradle that held them upright much like the cradle that is described in the plans. I then rolled the cradle in a truck and strapped the whole dealio down. Got the wings to the airport safe and stored them like that for a long time.
Hope this helps and good luck on your move,
Leaker
