08-06-2010, 04:37 PM
Tire pressure
Is it common for new RV tires to not hold pressure (maybe the rubber is still stretchy)?
Mine never went flat, even sitting for a year never being toppped up. But the last few weeks, I would top them up (40psi mains, 35psi nose) and they would lose 5-10psi over the course of a couple of weeks. I've had to top up the tire pressure before my first and second flights (less than 2 weeks apart).
Normal?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
08-06-2010, 06:15 PM
no
I have not had to put any air in. My mains from new about 1 year. The nose I filled twice.
Mike Johnson
8A N484M
08-06-2010, 06:51 PM
It's tolerated
I lose about 3-5 psi per week from my 9A mains and about 5 psi per month from the nose tube. Vans stock tubes all around. Yes, the Schraders are tight and I have the good caps with the o-ring inside.
Perhaps I'll get the high dollar Michelin tubes next tire change.
Five Sierra Fox
RV-9A
Utah
08-06-2010, 06:59 PM
Down the Road, You Might Look Into New Tubes
Phil:
Approaching nearly 600 hours, and I've had very few issues with my RV. That said, I'm just on my third alternator and the original Vans tubes were problematic as well. Pressure issues and then flats all around, and coming at the seams - so it was not an issue with pinching or improper installation. Mains are now Michelin AirStops. So far, so good.
Terry, CFI
RV-9A N323TP
08-06-2010, 07:20 PM
Do the caps actually do anything other than protect the tip of the valve? I actually lost one of my plastic caps and haven't bothered replacing it...
Are these the "good caps" you're referring to?
ACS 2525 VALVE CAP MS20813-1B
http://www.aircraftspruce.ca/catalog...s/valvecap.php
Phil
RV9A (SB)
Ottawa, Canada
08-06-2010, 08:21 PM
Mine haven't lost any pressure in 2 months.
Tony Phillips
N524AP, RV 9 (tail wheel)
08-06-2010, 08:42 PM
Super Moderator
I started with Van's standard issue tubes (back in early 2000's) when I was building and they were constantly losing air even sitting in the shop. I'd add air almost every week. Before I flew the first flight, I switched to Michelin Air Stops (50 psi). I now add air about every three months. In my opinion, they're worth the extra cost.
Chris
Chris Pratt (2020 VAF DUES PAID)
RV-8 Flying, 850+hours
N898DK
Lycoming O-360-A1A, Hartzell CS
52F (Northwest Regional, Aero Valley, Whatever, TX)
08-06-2010, 10:13 PM
Guess I got lucky. I put in the original Vans-supplied tubes (after pinching a hole in the first nose tube) and they have never required additional air. I changed the tires (mains) before leaving for a recent trip, reinstalled the tubes, and they have held up fine for the past month.
Given the diversity of things that are reported here, it seems that some are leakers to various degrees and some are not.
greg
Greg Arehart
N 7965A
08-07-2010, 05:36 AM
about those caps, do they actually do anything other than protect the tip of the valve? I actually lost one of my plastic caps and haven't bothered replacing it...
Are these the good metal caps a few have mentioned in other threads?
Phil
RV9A (SB)
Ottawa, Canada
08-07-2010, 07:01 AM
Chris
Same here. The Michelin Air Stops are the cat's meow, especially for an old geezer getting tired of crawling around the floor pumping up tires. I service mine front and rear to 45 psi no more than twice a year.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
