Old 08-06-2010, 01:12 PM
bobby bobby is offline
Default 121.5 ELT Install
Has anyone heard about DAR's not approving a 121.5 ELT installation anymore? I seem to remember hearing that but am not sure where from. I spent some time in the FAR's and it looks like the FAA still allows an installation of a 121.5 ELT for compliance with the FAR's.
Bob Anderson, VAF #2337
RV-8 Flying!!!
Old 08-06-2010, 01:58 PM
It looks like it was a FCC thing and not effective yet if ever. So I would assume a DAR would have to allow a 121.5 ELT installation.
RV-8 Flying!!!
Old 08-06-2010, 02:24 PM
Mel's Avatar
Mel Mel is offline
At this time you are required to have an ELT that automatically transmits on 121.5, 243 or 406 MHz.
Most, if not all ELTs now being manufactured transmit on 121.5 MHz.
Even the 406 MHz units transmit on 121.5 for local SAR.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 08-06-2010, 04:24 PM
apkp777's Avatar
apkp777 apkp777 is offline
Sure, you can still install a 121.5, and have I got a deal for you!
Tony Phillips
N524AP, RV 9 (tail wheel)
Old 08-26-2010, 12:58 PM
SmittysRV's Avatar
SmittysRV SmittysRV is offline
Sooooo..... It's OK for me to go ahead and install the 121.5 ELT I bought right before the announcement?
Smitty
Old 08-26-2010, 01:30 PM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
There is NO, ZIP, NADA rule that I know of that precludes installing a 121.5 MHz ELT in the USA today. Correct me if I am wrong which is unlikely.
Old 08-26-2010, 01:39 PM
vic syracuse vic syracuse is offline
Super Moderator
Ron Lee, you are correct. As a DAR, I also believe that there is some room in 91.207 to question whether the ELT is actually needed for Phase I testing:
To quote:
(f) Paragraph (a) of this section does not apply to--
(4) Aircraft while engaged in flight operations incident to design and testing;
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Mel's Avatar
Mel Mel is offline
Default Your are Correct!
121.5 ELTs are as legal as they ever were.
And Vic is correct in that the ELT is NOT required during phase I. However, if you do not have one installed for the initial inspection, the DAR may only sign off for phase I and require another inspection with the ELT installed for phase II.
Old 08-26-2010, 01:48 PM
Ron Lee's Avatar
Vic, I can't argue the regs but isn't there one requiring an ELT for aircraft that go beyond some distance (25 nm?) of their airport? If so, that should apply in my opinion.
Old 08-26-2010, 02:11 PM
Super Moderator
Here it is in it's entirety. I don't see the 25 mile reference.
Sec. 91.207
Emergency locator transmitters.
(a) Except as provided in paragraphs (e) and (f) of this section, no person may operate a U.S.-registered civil airplane unless--
(1) There is attached to the airplane an approved automatic type emergency locator transmitter that is in operable condition for the following operations, except that after June 21, 1995, an emergency locator transmitter that meets the requirements of TSO-C91 may not be used for new installations:
(i) Those operations governed by the supplemental air carrier and commercial operator rules of parts 121 and 125;
(ii) Charter flights governed by the domestic and flag air carrier rules of part 121 of this chapter; and
(iii) Operations governed by part 135 of this chapter; or
(2) For operations other than those specified in paragraph (a)(1) of this section, there must be attached to the airplane an approved personal type or an approved automatic type emergency locator transmitter that is in operable condition, except that after June 21, 1995, an emergency locator transmitter that meets the requirements of TSO-C91 may not be used for new installations.
(b) Each emergency locator transmitter required by paragraph (a) of this section must be attached to the airplane in such a manner that the probability of damage to the transmitter in the event of crash impact is minimized. Fixed and deployable automatic type transmitters must be attached to the airplane as far aft as practicable.
(c) Batteries used in the emergency locator transmitters required by paragraphs (a) and (b) of this section must be replaced (or recharged, if the batteries are rechargeable)--
(1) When the transmitter has been in use for more than 1 cumulative hour; or
(2) When 50 percent of their useful life (or, for rechargeable batteries, 50 percent of their useful life of charge) has expired, as established by the transmitter manufacturer under its approval.
The new expiration date for replacing (or recharging) the battery must be legibly marked on the outside of the transmitter and entered in the aircraft maintenance record. Paragraph (c)(2) of this section does not apply to batteries (such as water-activated batteries) that are essentially unaffected during probable storage intervals.
(d) Each emergency locator transmitter required by paragraph (a) of this section must be inspected within 12 calendar months after the last inspection for--
(1) Proper installation;
(2) Battery corrosion;
(3) Operation of the controls and crash sensor; and
(4) The presence of a sufficient signal radiated from its antenna.
(e) Notwithstanding paragraph (a) of this section, a person may--
(1) Ferry a newly acquired airplane from the place where possession of it was taken to a place where the emergency locator transmitter is to be installed; and
(2) Ferry an airplane with an inoperative emergency locator transmitter from a place where repairs or replacements cannot be made to a place where they can be made.
No person other than required crewmembers may be carried aboard an airplane being ferried under paragraph (e) of this section.
[ (1) Before January 1, 2004, turbojet-powered aircraft; ]
(2) Aircraft while engaged in scheduled flights by scheduled air carriers;
(3) Aircraft while engaged in training operations conducted entirely within a 50-nautical mile radius of the airport from which such local flight operations began;
(5) New aircraft while engaged in flight operations incident to their manufacture, preparation, and delivery;
(6) Aircraft while engaged in flight operations incident to the aerial application of chemicals and other substances for agricultural purposes;
(7) Aircraft certificated by the Administrator for research and development purposes;
(8) Aircraft while used for showing compliance with regulations, crew training, exhibition, air racing, or market surveys;
(9) Aircraft equipped to carry not more than one person; and
(10) An aircraft during any period for which the transmitter has been temporarily removed for inspection, repair, modification, or replacement, subject to the following:
(i) No person may operate the aircraft unless the aircraft records contain an entry which includes the date of initial removal, the make, model, serial number, and reason for removing the transmitter, and a placard located in view of the pilot to show "ELT not installed."
(ii) No person may operate the aircraft more than 90 days after the ELT is initially removed from the aircraft; and
[(11) On and after January 1, 2004, aircraft with a maximum payload capacity of more than 18,000 pounds when used in air transportation.]
Vic Syracuse
