  #21
Old 03-05-2006, 08:03 PM
starkw1 starkw1 is offline
Default Surgical clamps or forceps
Here is another handy tool for getting bolts, washers, or other small objects into tight places - surgical clamps or forceps. These have longer handles and " noses" compared to a standard hemostat. Long handles and long nose make them able to grip large and small objects. Standard fare in any OR. Can sometimes be found on Ebay for ~$10.
Warren
RV-7
Plymouth, MN
http://img132.imageshack.us/img132/7...p1small4yd.jpg
http://img228.imageshack.us/img228/9...p2small6rp.jpg
Old 03-05-2006, 08:12 PM
KTM520guy's Avatar
KTM520guy KTM520guy is offline
The cheapest and easiest tools to use are hemostats. I picked up mine for $2. But really, it's all in how you hold your tongue.
RV-8A builder
A&P mechanic
Aviation Plasticized Pigmented Polymer Application Engineer
Old 06-01-2006, 02:06 PM
jlfernan's Avatar
jlfernan jlfernan is offline
But then, after the nut, bolt and washer are in place, how do you torque them? My wrench is too big to fit is between the skin and the nut.
http://www.mykitlog.com/JorgeF
Jorge Fernandez
Spruce Creek, FL
Old 06-02-2006, 01:07 AM
rv8ch's Avatar
rv8ch rv8ch is online now
Default Torquing
You'll just have to do it by feel, or get a crow's foot extender for your torque wrench.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 06-02-2006, 07:11 AM
briand's Avatar
briand briand is offline
I just put a pc of 2x4 under the aft end of the H-S and the fore end of the elevator which allowed the trailing edge of the elevators to "hang" down and that gave me tons of room to use a standard needle nose. With a little taller block you could probably use your fingers.
Old 06-02-2006, 08:10 AM
DGlaeser DGlaeser is offline
Default Hinge bolt torque
Torque on those bolts is not critical. Snug it up and you're good to go. Actually what most would call 'snug' is probably more torque than specified for an AN3 bolt The main reason for 'snugging' the bolt is to force the rotation to occur in the bearing, and not have the hinge brackets rotate around the bolt.
Dennis Glaeser CFII
Rochester Hills, MI
RV-7A - Eggenfellner H6, GRT Sport ES, EIS4000, 300XL, SL30, TT Gemini, PMA6000, AK950L, GT320,
uAvionixEcho ADSB in/out with GRT Safe Fly GPS
Old 06-02-2006, 12:49 PM
caryr's Avatar
caryr caryr is offline
a pair of 8 or 10 inch off set needle nose pliers are very handy for all of those tight places, this one in particular.
Off set -- meaning the last 2 inches of plier is bent over on a 45 deg angle or so.
cary r
Cary Rhodes
Taylorsville, Georgia
N203CR
Van's RV-7
First Flight April 2004
