I use a pair of long forceps that were given to me by friend that makes dental crowns. Also I took a couple of an3 bolts and ground a point on the threded end and welded a piece of welding rod on the head. Works great for aligning the hinges.
Probably the best tool for putting on the rudder, elivators and ailerons is the ratchet box end wrench. I thought I was getting a pretty good deal at Harbor freight for about $40.00 for a set until I found practically the same thing at Costco for about $20.00. Earlier I had purchased just the 3/8 ratchet box end through Sears for about $12.00. As you can see, the sets are a better buy.
