08-04-2010, 07:10 PM
LED Dimmer
Will the Panel Dimmer that Van's sells (ES DIMMER, LAMP 1.5A) work with LED strips ? I realize that LEDs require PWM circuits.
Phelps
08-04-2010, 08:01 PM
Yes it will. You do not have to use PWM to dim LED's...
08-05-2010, 03:30 AM
LEDs and PWM
Thanks, I had read posts stating that this was required. I take it you have done this with a non PWM dimmer. Thanks
phelps
08-05-2010, 05:34 AM
Yes I have....there are many reasons why driving LED's with constant current, PWM etc. is better than variable voltage sources but in this case, it is just to plain simple and inexpensive to bother with the textbook correct way to do it.
Cheap and it works just fine!!
PS: Don't get snookered into buying those overpriced LED strips that are being sold out there....The inexpensive <$10 models that you can get at your local Walmart or Autozone work just fine in an airplane.......
08-05-2010, 06:19 AM
LED Dimmer
FWIW, I visited my local Radio Shack and for less than $10 apiece, I was able to build two dimmer controls and they are the PWM type and work very well.
Jerry Fischer KW4F
VAF# 1646
USS Randolph CVS-15 V-6 Div. AT2
RV7 N364SJ Miss Sandy sold
RV1 N1583 "Mockingbird 1" SOLD
EAA volunteer SNF
HBC volunteer/co-chairman OSH
Tech counselor
08-05-2010, 07:34 AM
Did the same thing...I bought two strips for $15 on eBay, used one on the panel, plus the $25 dimmer, and I have less than $35 in my panel lights!
Chad Jensen
Astronics AES, Vertical Power
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
