Old 03-01-2006, 11:42 AM
Davepar's Avatar
Davepar Davepar is offline
Default Engine Baffle Pictures
I've been doing some research on engine baffling and found a bunch of great pictures that have been helpful. Everybody seems to do little things slightly differently, especially in the area of the cowl inlets and around the prop governor line. And of course there are lots of engine variants.
Dan's site (IO-360, angle valve, horz induction, custom intake):
http://www.rvproject.com/construction_log.html#cowling
Walter's site (IO-360, parallel valve, horz induction, custom intake):
http://www.rv7-a.com/baffling.htm
Phil's site (IO-360, parallel valve, vert induction):
http://www.myrv7.com/baffles.php
Vern's site (IO-320, vert induction):
http://www3.telus.net/aviation/flyin...wd_photos.html
Ren? and friends (IO-360, parallel valve, horz induction, FADEC):
http://websites.expercraft.com/PHVII...=log_list&c=58
Carl's (IO-360, parallel valve, vert induction, FADEC, plenum):
http://www.rvproject.gen.nz/baffles.html
Please post if you find others.
Dave
(added corrections from Carl)
Dave Parsons, Seattle, WA, RV-7A, sold
www.dualrudder.com/rv7 - building blog
RunwayFinder.com - airport info, online charts, live METARs, TFRs, etc.
Old 03-01-2006, 12:19 PM
ClayR_9A's Avatar
ClayR_9A ClayR_9A is offline
http://www.eaachapter.com/fwfshots/
Old 03-01-2006, 12:49 PM
sprucemoose's Avatar
sprucemoose sprucemoose is offline
http://home.mindspring.com/~rv6/RV6site/plenum.htm
This is a plenum based on Van's baffle kit. O-360 parallel valve, vert induction.
Jeff Point
RV-6, RLU-1 built & flying
Tech Counselor, Flight Advisor & President, EAA Chapter 18
Milwaukee
Old 03-01-2006, 08:18 PM
bhester's Avatar
bhester bhester is offline
Smile Here's my RV7A XP-O360 baffle page
http://members.hopkinsville.net/bhester/Baffling.htm
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2019 VAF donator - alot better than any magazine subscription
Old 03-01-2006, 11:51 PM
godspeed's Avatar
godspeed godspeed is offline
Default Baffling is a proper name for them
Out off all the aircraft names and such this one matches best to the true name for these things..
a puzzle at best..
Just wanted to say thanks for starting this tread,
I just (almost) completed the cowling fit, and this is my next step, spent most of today making that bracket that fills the void for the nose wheel, not much on the plans for those sizes of parts I had to make, .. turned out ok inspite of the rv9a page 45 plans.. couldn't find anything online to double check
just wanted to say thanks..
Danny..
Old 03-02-2006, 09:52 AM
Davepar's Avatar
Thanks for the extra picture links. They look great. I'm especially impressed/amazed at the guys that do the plenums.
Originally Posted by godspeed
...spent most of today making that bracket that fills the void for the nose wheel, not much on the plans for those sizes of parts I had to make...
Sounds like the perfect warm-up for the baffles.
The best help I've had on the baffles is just looking at how others have done them. As you start to work on each new section or if you run into a confusing area, go back and look at the pictures again.
More tips:
- The baffles for the 200hp are slightly different than the 180hp.
- The intake filter/snorkel for the horizontal/forward-facing induction imposes some special requirements on the front left baffle floor. Read the instructions for the snorkel and do some trial fitting before cutting the left baffle floor.
Old 03-02-2006, 06:29 PM
Tony Kirk's Avatar
Tony Kirk Tony Kirk is offline
Default Lycoming O-320-H2AD Baffles
Here is a link to some pictures of my scratch-built O-320-H2AD baffles...
http://www.eaa582.org/gallery/thumbnails.php?album=19
(drill down to about the 4th page).
The H2AD provided its own special challenges and I mounted my oil cooler on the right rear, behind #3 cylinder partly because my oil lines are on the right side of the oil filter housing, and to provide clear routing for the fuel lines going to the forward mounted fuel pump (left front).
I've had no problems with high temps even when flying in 95* OAT. I do have to lower the nose and increase the airspeed on hot-day extended climb-outs to keep #3 under 425* (my EIS4000 warning setting), basically I just transition to cruise-climb a little sooner (2,000 agl or so).
I'm now past 100 hours with no cracks or other problems.
Tony Kirk
Van's Aircraft Tech Support
Building RV-7 (N777RV Reserved)
RV-6A N57TK (sold)
First flight 9/5/05...
Sold in 2011 after 725 hours of pure joy!
Last edited by Tony Kirk : 04-07-2006 at 10:22 PM. Reason: Update web link for photos.
Old 03-03-2006, 12:47 AM
mark manda's Avatar
mark manda mark manda is offline
at the risk of boring you with yet even more picts-
http://www.pbase.com/mark2nite/engine_baffling
Old 03-03-2006, 11:24 AM
Davepar's Avatar
not bored yet. The paint on the airbox looks very cool.
I started a new thread for a couple of baffle questions that I have:
http://www.vansairforce.com/communit...ead.php?t=6128
