08-04-2010, 09:44 AM
lightspeed need cooling?
Does my lightspeed elec ign module need a blast tube feeding coolinbg air to it (the way a mag does)? I don't want to waste cooling air pressure if the lightspeed doesn't need this.
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
08-04-2010, 09:49 AM
I'm pretty sure Lightspeed recommends mounting the controller on the cold side of the firewall. If it was on the hot side, sounds like a good idea. If you mean the coil, no, it isn't as heat sensitive.
Scott Card
CMW E-Lift
08-04-2010, 09:57 AM
I'm actually wondering about the part that mounts to the back of the engine, where the mag would normally go... I think its called the hall effect sensor. Does this need a blast of cooling air the way a mag does?
Phil
RV9A (SB)
Ottawa, Canada
08-04-2010, 11:24 AM
phil I do not believe the Hall sensor needs a blast tube but if you have the Plasma III system Klaus reccomends directing some cooling air into the unit using a standard avionics or computor type fan. The plasma III unit has a plastic tube tube that can be used for air intake.
Tom Martin RV1 pilot 4.6hours!
CPL & IFR rated
EVO F1 Rocket 1000 hours,
2010 SARL Rocket 100 race, average speed of 238.6 knots/274.6mph
RV4, RV7, RV10, two HRIIs and five F1 Rockets
RV14 Tail dragger
Fairlea Field
St.Thomas, Ontario Canada, CYQS
fairleafield@gmail.com
08-04-2010, 08:18 PM
Hall Effects cooling
Hello Phil
I've got dual LSE system on my RV-4 with Hall Effects and I have a blast tube directed at each of them.. The loss of cooling air is to my believe minimal vs the Hall Effects benefits of being kept cool IMHO
Bruno
RV-4 C-GDBH
rv4@videotron.ca
08-05-2010, 06:37 AM
Super Moderator
I did put a cooling blast tube on the LSE Hall effect sensor on my RV-7A. I don't know if it is absolutely needed, but I am a firm believer in cooling electronics to prolong the life.
Vic
 Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
08-10-2010, 09:05 PM
Had a LS 2 with Hall Effect; flew 450 hrs no blast tube no problem.
LS version has no bearing on the Hall Effect sensor, which is the same unit no matter the control unit used.
08-10-2010, 09:12 PM
Klaus states he tests the control box past 200 degrees F for failure mode, I run 102 degree F in flight on the firewall. This install was discussed with Klaus, and he states it's not an issue. Ground taxi you will see 140 degrees F on the high side MAX on my install. The Hall Effect set-up WILL be much higher in temp at the unit.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
08-11-2010, 12:17 AM
That vent is only on the 6-cylinder box. Klaus' website has a 'service bulletin' link that discusses it and says it is not required for the 4-cylinder versions.
EAA Technical Counselor #5357
