As you know ....
...you're sizing that feed for when the E-bus switch is closed and your feeding all the E-bus loads from the batt bus. That wire - for most of us - is only about 3 to 4' long. That said, 10awg is normally good for 30A, while a 14awg is fused at 15A and a 12awg at 20A. You can add up the amps of your E-bus connected load and build accordingly.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
