Old 08-03-2010, 01:17 PM
DanH's Avatar
DanH DanH is offline
Default Tip: Wing Handling Fixture
Idea starter, plenty of variations. Build from scrap. Sure does make prep, paint, polish and transport easy to do. With this on the tip rib all you need are two sawhorses.
1/2" angle, some plate and a length of pipe. (One leg is short here to clear a mag bracket.)
Attach to end rib with six #8's or #10's.
Wing will sit upright on the spar, or flat with the addition of a 2x2.
Dan Horton
RV-8 SS
Barrett IO-390
Old 08-03-2010, 08:00 PM
instructor_bill instructor_bill is offline
Default Love it!
I wasn't sure how I was going to handle that one and skipped paint while I had both the space, and the chance because I hadn't wrapped my head around that one.
If finances prevent me from moving foreward with the finish kit, paint will be next. Fuse in a rotisserie and wings on horses. I simply love it.
Thanks for posting Dan!
Bill Mason
RV7 SB in construction
Avionics, Wiring, FWF, interior, and paint to go.
Old 08-15-2010, 02:36 PM
mike newall's Avatar
mike newall mike newall is offline
We used a similar technique which didn't need welding - pinched it from here
http://www.romeolima.com/RV8/Paint.h...ting%20process
Pinched his colour scheme as well but we did ask first...........
Old 08-16-2010, 10:22 AM
Bill Phillips Bill Phillips is offline
Default Dan
I made a device to support and spin the wing while painting. The large lightening holes behind the spar will accept a 4.5 inch PVC pipe. I got two such pipes of a total of 12 feet; stuck them in from both ends and wired together at the bellcrank. Then I built two saw horses and cut notches for the pipe to rest in. I use a piece of 2 inch PVC pipe in the smaller end hole as the brake/ stop. All cost about $20. for the wood and pipe and took 30 mimutes to build. Works great! Sorry I don't have a photo. Best regards, Bill of Georgia
Old 08-16-2010, 04:55 PM
Danny7 Danny7 is offline
dan do you have to drill new holes for the attach screws? you are attaching to the rib, rather than the skin?
nothing special here...
Old 08-16-2010, 07:33 PM
DanH's Avatar
Yes, through the rib near the flange. Same for Randy's pipe bracket n' plywood method. Bill's PVC pipe method is pretty cool too.
Dan Horton
RV-8 SS
Barrett IO-390
Old 08-17-2010, 06:06 PM
pilotjt's Avatar
pilotjt pilotjt is offline
Default Great idea Dan..
I'm looking forward to seeing that paint job too...
Regards,
JT
RV8-N110JT
www.jtsrv8project.blogspot.com
KVPC
Old 08-17-2010, 07:55 PM
pat pat is offline
Location: Midland, Michigan 3BS Hanger 4B and sometimes at home
Default what paint
and system are you using? I enjoy reading about your progress and process, please give paint updates if you have time.
Patrick Howe
Citabria 7KCAB - sold
RV8A FB - flying
Old 08-23-2010, 06:26 PM
bill phillips photos thread http://www.vansairforce.com/communit...ad.php?t=61675
