Old 08-02-2010, 04:03 PM
Christopher Murphy Christopher Murphy is offline
Default Aeroquip fittings 816d-6
I am getting ready to fab new fuel lines for the RV-4. Are aeroquip 816 type fittings reusable? Used with 601/701 hose.
CM
Old 08-03-2010, 06:19 AM
vic syracuse vic syracuse is offline
Super Moderator
Yes, they are reuseable. Do check them for serviceability after you disassemble the current hose, and then make sure you put a drop of oil on the threads when reassembling.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Old 08-03-2010, 09:50 AM
Scott Hersha Scott Hersha is offline
Also make sure there are no pieces of hose rubber stuck down in between the cutter and nipple. Just dig any of that out with a pick.
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
Cincinnati, OH/KHAO
JAN2020
Old 08-03-2010, 02:31 PM
Default rubber stuck between nipple and cutter.
I took the fittings off the hose and there is rubber stuck in that slot. I tried to get it out but I can't find a tool small enough and strong enough to get it out. Any suggestions?
Chris M
Old 08-03-2010, 02:54 PM
Mel's Avatar
Mel Mel is offline
Chris M
Dental pick!
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 08-03-2010, 04:45 PM
mtnflyer mtnflyer is offline
Chris
I have the mandrels for the AQ fittings and will back to FNL by 10 or 11 thurs morning..dave cook
Old 08-03-2010, 05:44 PM
ThisOne ThisOne is offline
Chris M
Chris,
As already noted a dental pick is an ideal tool for this, another thing that I have found to work is the "tab" that is left over from a Band-it?. The stainless steel "tab" is thin enough to work your way down and around thus ensuring that you remove all of the left over hose.
Regards,
Brett
Brett
Bonaco, Inc.
brett@bonacoinc.com
and
bonacoinc@bonacoinc.com
1-909-985-3429
Old 08-04-2010, 07:59 AM
Default Radio Shack Soldering Tools
Chris I was in Radio Shack during my recent Terra NAV to Garmin SL-30 modification and I bought a small pack of soldering tools that I thought might be useful. It is out at the hangar now but as I recall there were six black double ended tools with a central red plastic gripping surface. They included both straight and curved tips. I've never used them for your task but I can imagine using them because of their configuration and size.
Bob Axsom
Old 08-04-2010, 02:00 PM
Default thanks
Thanks for the tips. I have a dental pick but its too big to fit in the gap. I'll figure something out or get new fittings. thanks for the tips.
I much prefer 303 hose and 491 fittings but this is what I had origionally and I have not had vapor lock issues so I was trying to keep it the same.
CM
Old 07-26-2011, 08:01 PM
AlexPeterson's Avatar
AlexPeterson AlexPeterson is online now
Default Aeroquip 816 fittings
Anyone have any good ideas for getting the little ring of rubber out of the fittings?
I rebuilt some -8 hoses, no problem, the little piece of rubber comes right out. However, the -4 all leave the piece of rubber inside the fitting upon disassembly. Very miserable process removing it, nothing very strong can fit in there. I used a small drill bit in a pin vise, and chewed away at it. Took maybe 45 minutes to clean out two of them.
The -4 parts are cadmium plated steel, so perhaps heating to 500F (cadmium melting point about 600F) or so might destroy the rubber. I took a torch to one, but wrecked it by melting the cadmium.
Perhaps some sort of solvent will work - I'm not sure what rubber is in the old 601 hose.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
