Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 08-02-2010, 01:00 PM
pierre smith's Avatar
Default How to control a 496 from a 430W
This past weekend, I gave a BFR to a gent in his GRT/430W/496 equipped -9A and we flew to KAGS for an ILS 17 approach.
On the way there, he showed me that whatever go-to waypoint he put in the 430W, it automatically also put it in the 496.
Any of you guys know how it should be wired to do that?.... I don't have any schematics or manuals here,
[ed. Thread moved to more appropriate area. dr]
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 08-02-2010, 01:25 PM
mburch's Avatar
mburch mburch is offline
Here you go Pierre, this should be what you're after: http://www.vansairforce.com/communit...p?t-29934.html
Apologies if that doesn't format as a proper URL, I'm using my phone to browse VAF from the Minneapolis airport terminal...
mcb
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
Old 08-02-2010, 04:30 PM
339A's Avatar
339A 339A is offline
Default PDF File
I have designed this into my panel upgrade. Here is a link to a pdf file of my electrical drawings. Sheet 8 shows the wiring interface to a 696. I added a switch to be able to disconnect the flight plan data to the 696. My understanding is that while the 696 is receiving serial data you can not select a different flight plan independent of what the 430 is sending it. Thus the switch...
Scott Mills, Front Range, CO
N339A - 1900 Hours!! since 9/11/05
Like Us on Facebook: https://www.facebook.com/ScottandDeb...tures/timeline
Airport Landings
"In order to discover new lands one must have the courage to lose sight of the shore." Andre Gide
"Never feel sorry for a man who owns a plane" Charles Morse (Anthony Hopkins) in The Edge
