Old 07-30-2010, 07:56 AM
turbo's Avatar
turbo turbo is offline
Talking wheelpant bracket cracks
keep an eye on your wheelpant bracket for cracks. this tab of mine was broke off. ower MRO shop put some material back on then fred stucklen help me rivet on a doubler. we did both sides. the runway here is not very smooth and has been very hard on lots of the planes flying out of here. seeing that i bought my plane in 1999 this was the first rivet i have ever done. having built 3 rvs fred was an huge help. thanks fred. i think i will be beefing up the outer bracket that attaches to the axil nut.
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
Old 07-30-2010, 01:04 PM
terrykohler terrykohler is offline
Default Looks Like You've Got a Clearance Problem as Well
Ed:
The radial scoring marks around the back side of the bracket may eventually lead to failure there. Easily fixed by increasing the length of the spacers holding the bracket off the brake assembly. Looks like around .060 should do it. I had to take the cure myself.
Terry, CFI
RV-9A N323TP
Old 07-30-2010, 05:53 PM
turbo's Avatar
Talking terry...........
thanks for the info. turbo
Ed D'Arcy
Old 07-30-2010, 11:32 PM
dhall_polo's Avatar
dhall_polo dhall_polo is offline
Default Better part
http://www.fairings-etc.com/brackets.htm
This bracket is prone to failure. See link for the solution/upgrade.
Good luck!
Don Hall
N517DG - RV7 - Flying!
Ticked Van's Hobbes meter at #6110, 3/7/09
Old 07-31-2010, 07:56 PM
rv9av8tr's Avatar
rv9av8tr rv9av8tr is offline
Default stainless?
Is this part Al or stainless.?
Long-EZ built 1985 -> Sold 2007
RV-9A; N539RV First Flight: 7/2010
RV-8A N468DL 40 hr Flight Test Program
Building Log: www.mykitlog.com/n539rv
APRS Tracking: aprs.fi/n539rv
2017 Paid
Old 08-01-2010, 05:27 AM
turbo's Avatar
Talking the original is AL, ............
replacement SS. i think the doubler will work fine. easy fix. we will see. the runway at 7B6 skylark is a real test. a tooth rattler on landing.
Ed D'Arcy
Old 08-01-2010, 10:33 AM
rocketbob's Avatar
Personally I've always thought the wheelpant attachment design Van came up with had a lot to be desired. I rolled my own for my rocket. Details here: http://picasaweb.google.com/rocketbo...eat=directlink
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
